[petsc-users] [petsc-maint #107932] run a simple example ex19 in src/snes/examples/tutorials
    Xiangze Zeng
    zengshixiangze at 163.com
    Thu Mar 15 20:24:24 CDT 2012
I can see log_summary output when I use -log_summary [filename].
But the time of inserting the matrices values is almost the same when I use PCJACOBI  to run the code on GPU instead of PCSOR.They are all much longer than that when I run the code in CPU(I still use a small system to test it). The attachments are outputs of log_summary, c_jacobi_sum is the output of using CPU, PCJACOBI;g_sor_sum using GPU, PCSOR;g_jac_sum using GPU, PCJACOBI.
Zeng
在 2012-03-15 22:26:41,"Jed Brown" <jedbrown at mcs.anl.gov> 写道:
2012/3/15 Xiangze Zeng <zengshixiangze at 163.com>
Sorry, someting is wrong with my file which stores the size of the matriex.
But I still can't see -log_summary output. I just see at the first time, after that, never.
It is written by PetscFinalize(). Find out why you don't get there. Also note that the option needs to be visible at PetscInitialize (through the command line/options file/environment).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0007.obj>
