[petsc-users] GAMG issue
John Mousel john.mousel at gmail.com
Thu Mar 15 11:21:20 CDT 2012
Mark,
I ran with those options removed (see the run options listed below). Things
actually got slightly worse. Now it's up to 142 iterations. I have attached
the ksp_view output.
-ksp_type bcgsl -pc_type gamg -pc_gamg_sym_graph -ksp_diagonal_scale
-ksp_diagonal_scale_fix -mg_levels_ksp_type richardson -mg_levels_pc_type
sor -pc_gamg_verbose 1
John
On Thu, Mar 15, 2012 at 10:55 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> John, can you run again with:  -pc_gamg_verbose 1
> And I would not use: -pc_mg_levels 4 -mg_coarse_ksp_type preonly
> -mg_coarse_pc_type sor -mg_coarse_pc_sor_its 8
> 1) I think -mg_coarse_ksp_type preonly and -mg_coarse_pc_sor_its 8 do not
> do what you think.  I think this is the same as 1 iteration.  I think you
> want 'richardson' not 'preonly'.
> 2) Why are you using sor as the coarse solver?  If your problem is
> singular then you want to use as many levels as possible to get the coarse
> grid to be tiny.  I'm pretty sure HYPRE ignores the coarse solver
> parameters.  But ML uses them and it is converging well.
> 3) I would not specify the number of levels.  GAMG, and I think the rest,
> have internal logic for stopping a the right level.  If the coarse level is
> large and you use just 8 iterations of sor then convergence will suffer.
> Mark
> On Mar 15, 2012, at 11:13 AM, John Mousel wrote:
> Mark,
> The changes pulled through this morning. I've run it with the options
> -ksp_diagonal_scale_fix -pc_mg_levels 4 -mg_levels_ksp_type richardson
> -mg_levels_pc_type sor -mg_coarse_ksp_type preonly -mg_coarse_pc_type sor
> and it converges in the true residual, but it's not converging as fast as
> anticpated. The matrix arises from a non-symmetric discretization of the
> Poisson equation. The solve takes GAMG 114 iterations, whereas ML takes 24
> iterations, BoomerAMG takes 22 iterations, and -ksp_type bcgsl -pc_type
> bjacobi -sub_pc_type ilu -sub_pc_factor_levels 4 takes around 170. I've
> attached the -ksp_view results for ML,GAMG, and HYPRE. I've attempted to
> make all the options the same on all levels for ML and GAMG.
> Any thoughts?
> John
> On Wed, Mar 14, 2012 at 6:04 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> Humm, I see it with hg view (appended).
>> Satish, my main repo looks hosed.  I see this:
>> ~/Codes/petsc-dev>hg update
>> abort: crosses branches (merge branches or use --clean to discard changes)
>> ~/Codes/petsc-dev>hg merge
>> abort: branch 'default' has 3 heads - please merge with an explicit rev
>> (run 'hg heads .' to see heads)
>> ~/Codes/petsc-dev>hg heads
>> changeset:   22496:8e2a98268179
>> tag:         tip
>> user:        Barry Smith <bsmith at mcs.anl.gov>
>> date:        Wed Mar 14 16:42:25 2012 -0500
>> files:       src/vec/is/interface/f90-custom/zindexf90.c
>> src/vec/vec/interface/f90-custom/zvectorf90.c
>> description:
>> undoing manually changes I put in because Satish had a better fix
>> changeset:   22492:bda4df63072d
>> user:        Mark F. Adams <mark.adams at columbia.edu>
>> date:        Wed Mar 14 17:39:52 2012 -0400
>> files:       src/ksp/pc/impls/gamg/tools.c
>> description:
>> fix for unsymmetric matrices.
>> changeset:   22469:b063baf366e4
>> date:        Wed Mar 14 14:22:28 2012 -0400
>> description:
>> added fix for preallocation for unsymetric matrices.
>> Mark
>> my 'hg view' on my merge repo:
>> Revision: 22492
>> Branch: default
>> Author: Mark F. Adams <mark.adams at columbia.edu>  2012-03-14 17:39:52
>> Committer: Mark F. Adams <mark.adams at columbia.edu>  2012-03-14 17:39:52
>> Tags: tip
>> Parent: 22491:451bbbd291c2 (Small fixes to the BT linesearch)
>> ------------------------ src/ksp/pc/impls/gamg/tools.c
>> @@ -103,7 +103,7 @@
>>    PetscErrorCode ierr;
>>    PetscInt       Istart,Iend,Ii,jj,ncols,nnz0,nnz1, NN, MM, nloc;
>>    PetscMPIInt    mype, npe;
>> -  Mat            Gmat = *a_Gmat, tGmat;
>> +  Mat            Gmat = *a_Gmat, tGmat, matTrans;
>>    MPI_Comm       wcomm = ((PetscObject)Gmat)->comm;
>>    const PetscScalar *vals;
>>    const PetscInt *idx;
>> @@ -127,6 +127,10 @@
>>    ierr = MatDiagonalScale( Gmat, diag, diag ); CHKERRQ(ierr);
>>    ierr = VecDestroy( &diag );           CHKERRQ(ierr);
>> +  if( symm ) {
>> +    ierr = MatTranspose( Gmat, MAT_INITIAL_MATRIX, &matTrans );
>>  CHKERRQ(ierr);
>>    /* filter - dup zeros out matrix */
>>    ierr = PetscMalloc( nloc*sizeof(PetscInt), &d_nnz ); CHKERRQ(ierr);
>>    ierr = PetscMalloc( nloc*sizeof(PetscInt), &o_nnz ); CHKERRQ(ierr);
>> @@ -135,6 +139,12 @@
>>      d_nnz[jj] = ncols;
>>      o_nnz[jj] = ncols;
>>      ierr = MatRestoreRow(Gmat,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>> CHKERRQ(ierr);
>> +    if( symm ) {
>> +      ierr = MatGetRow(matTrans,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>> CHKERRQ(ierr);
>> +      d_nnz[jj] += ncols;
>> +      o_nnz[jj] += ncols;
>> +      ierr = MatRestoreRow(matTrans,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>> CHKERRQ(ierr);
>>      if( d_nnz[jj] > nloc ) d_nnz[jj] = nloc;
>>      if( o_nnz[jj] > (MM-nloc) ) o_nnz[jj] = MM - nloc;
>> @@ -142,6 +152,9 @@
>>    CHKERRQ(ierr);
>>    ierr = PetscFree( d_nnz ); CHKERRQ(ierr);
>>    ierr = PetscFree( o_nnz ); CHKERRQ(ierr);
>> +  if( symm ) {
>> +    ierr = MatDestroy( &matTrans );  CHKERRQ(ierr);
>> On Mar 14, 2012, at 5:53 PM, John Mousel wrote:
>> Mark,
>> No change. Can you give me the location that you patched so I can check
>> to make sure it pulled?
>> I don't see it on the petsc-dev change log.
>> John
>> On Wed, Mar 14, 2012 at 4:40 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> John, I've committed these changes, give a try.
>>> Mark
>>> On Mar 14, 2012, at 3:46 PM, Satish Balay wrote:
>>> > This is the usual merge [with uncommited changes] issue.
>>> > You could use 'hg shelf' extension to shelve your local changes and
>>> > then do a merge [as Sean would suggest] - or do the merge in a
>>> > separate/clean clone [I normally do this..]
>>> > i.e
>>> > cd ~/Codes
>>> > hg clone petsc-dev petsc-dev-merge
>>> > cd petsc-dev-merge
>>> > hg pull ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev   #just to
>>> be sure, look for latest chagnes before merge..
>>> > hg merge
>>> > hg commit
>>> > hg push ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev
>>> > [now update your petsc-dev to latest]
>>> > cd ~/Codes/petsc-dev
>>> > hg pull
>>> > hg update
>>> > Satish
>>> > On Wed, 14 Mar 2012, Mark F. Adams wrote:
>>> >> Great, that seems to work.
>>> >> I did a 'hg commit tools.c'
>>> >> and I want to push this file only.  I guess its the only thing in the
>>> change set so 'hg push' should be fine.  But I see this:
>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg update
>>> changes)
>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg merge
>>> >> abort: outstanding uncommitted changes (use 'hg status' to list
>>> changes)
>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg status
>>> >> M include/petscmat.h
>>> >> M include/private/matimpl.h
>>> >> M src/ksp/pc/impls/gamg/agg.c
>>> >> M src/ksp/pc/impls/gamg/gamg.c
>>> >> M src/ksp/pc/impls/gamg/gamg.h
>>> >> M src/ksp/pc/impls/gamg/geo.c
>>> >> M src/mat/coarsen/coarsen.c
>>> >> M src/mat/coarsen/impls/hem/hem.c
>>> >> M src/mat/coarsen/impls/mis/mis.c
>>> >> Am I ready to do a push?
>>> >> Thanks,
>>> >> Mark
>>> >> On Mar 14, 2012, at 2:44 PM, Satish Balay wrote:
>>> >>> If commit is the last hg operation that you've done - then 'hg
>>> rollback' would undo this commit.
>>> >>> Satish
>>> >>>> Damn, I'm not preallocating the graph perfectly for unsymmetric
>>> matrices and PETSc now dies on this.
>>> >>>> I have a fix but I committed it with other changes that I do not
>>> want to commit.  The changes are all in one file so I should be able to
>>> just commit this file.
>>> >>>> Anyone know how to delete a commit?
>>> >>>> I've tried:
>>> >>>> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg strip 22487:26ffb9eef17f
>>> >>>> hg: unknown command 'strip'
>>> >>>> 'strip' is provided by the following extension:
>>> >>>>   mq  manage a stack of patches
>>> >>>> use "hg help extensions" for information on enabling extensions
>>> >>>> But have not figured out how to load extensions.
>>> >>>> Mark
>>> >>>> On Mar 14, 2012, at 12:54 PM, John Mousel wrote:
>>> >>>>> Mark,
>>> >>>>> I have a non-symmetric matrix. I am running with the following
>>> options.
>>> >>>>> -pc_type gamg -pc_gamg_sym_graph -ksp_monitor_true_residual
>>> >>>>> and with the inclusion of -pc_gamg_sym_graph, I get a new malloc
>>> error:
>>> >>>>> 0]PETSC ERROR: --------------------- Error Message
>>> >>>>> [0]PETSC ERROR: Argument out of range!
>>> >>>>> [0]PETSC ERROR: New nonzero at (5150,9319) caused a malloc!
>>> >>>>> [0]PETSC ERROR:
>>> >>>>> [0]PETSC ERROR: Petsc Development HG revision:
>>> 587b25035091aaa309c87c90ac64c13408ecf34e  HG Date: Wed Mar 14 09:22:54 2012
>>> -0500
>>> >>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> >>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> >>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> >>>>> [0]PETSC ERROR:
>>> >>>>> [0]PETSC ERROR: ../JohnRepo/VFOLD_exe on a linux-deb named
>>> wv.iihr.uiowa.edu by jmousel Wed Mar 14 11:51:35 2012
>>> >>>>> [0]PETSC ERROR: Libraries linked from
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/linux-debug/lib
>>> >>>>> [0]PETSC ERROR: Configure run at Wed Mar 14 09:46:39 2012
>>> >>>>> [0]PETSC ERROR: Configure options --download-blacs=1
>>> --download-hypre=1 --download-metis=1 --download-ml=1 --download-mpich=1
>>> --download-parmetis=1 --download-scalapack=1
>>> --with-blas-lapack-dir=/opt/intel11/mkl/lib/em64t --with-cc=gcc
>>> --with-cmake=/usr/local/bin/cmake --with-cxx=g++ --with-fc=ifort
>>> PETSC_ARCH=linux-debug
>>> >>>>> [0]PETSC ERROR:
>>> >>>>> [0]PETSC ERROR: MatSetValues_MPIAIJ() line 506 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>>> >>>>> [0]PETSC ERROR: MatSetValues() line 1141 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/interface/matrix.c
>>> >>>>> [0]PETSC ERROR: scaleFilterGraph() line 155 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/tools.c
>>> >>>>> [0]PETSC ERROR: PCGAMGgraph_AGG() line 865 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/agg.c
>>> >>>>> [0]PETSC ERROR: PCSetUp_GAMG() line 516 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/gamg.c
>>> >>>>> [0]PETSC ERROR: PCSetUp() line 832 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/interface/precon.c
>>> >>>>> [0]PETSC ERROR: KSPSetUp() line 261 in
>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>> >>>>> [0]PETSC ERROR: KSPSolve() line 385 in
>>> >>>>> John
>>> >>>>> On Wed, Mar 14, 2012 at 11:27 AM, Mark F. Adams <
>>> mark.adams at columbia.edu> wrote:
>>> >>>>> On Mar 14, 2012, at 11:56 AM, John Mousel wrote:
>>> >>>>>> Mark,
>>> >>>>>> The matrix is asymmetric. Does this require the setting of an
>>> option?
>>> >>>>> Yes:  -pc_gamg_sym_graph
>>> >>>>> Mark
>>> >>>>>> I pulled petsc-dev this morning, so I should have (at least close
>>> to) the latest code.
>>> >>>>>> John
>>> >>>>>> On Wed, Mar 14, 2012 at 10:54 AM, Mark F. Adams <
>>> >>>>>> On Mar 14, 2012, at 11:08 AM, John Mousel wrote:
>>> >>>>>>> I'm getting the following error when using GAMG.
>>> >>>>>>> petsc-dev/src/ksp/pc/impls/gamg/agg.c:508: smoothAggs: Assertion
>>> `sgid==-1' failed.
>>> >>>>>> Is it possible that your matrix is structurally asymmetric?
>>> >>>>>> This code is evolving fast and so you will need to move to the
>>> dev version if you are not already using it. (I think I fixed a bug that
>>> hit this assert).
>>> >>>>>>> When I try to alter the type of aggregation at the command line
>>> using -pc_gamg_type pa, I'm getting
>>> >>>>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error
>>> Message ------------------------------------
>>> >>>>>>> [1]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>> external package needed for type:
>>> >>>>>>> see
>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#external!
>>> >>>>>>> [1]PETSC ERROR: Unknown GAMG type pa given!
>>> >>>>>>> Has there been a change in the aggregation options? I just
>>> pulled petsc-dev this morning.
>>> >>>>>> Yes, this option is gone now.  You can use -pc_gamg_type agg for
>>> now.
>>> >>>>>> Mark
>>> >>>>>>> John
> <GAMG_kspview.txt><ML_kspview.txt><HYPRE_kspview.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120315/fdb4a2d5/attachment-0001.htm>
	[0]PCSetUp_GAMG level 0 N=58507, n data rows=1, n data cols=1, nnz/row (ave)=1, np=4
	[0]scaleFilterGraph 80.6997% nnz after filtering, with threshold 0.05, 6.43289 nnz ave.
	[0]maxIndSetAgg removed 0 of 13276 vertices.
		[0]PCGAMGprolongator_AGG New grid 7604 nodes
		[0]PCSetUp_GAMG 1) N=7604, n data cols=1, nnz/row (ave)=6, 4 active pes
	[0]scaleFilterGraph 93.3889% nnz after filtering, with threshold 0.05, 6.58382 nnz ave.
	[0]maxIndSetAgg removed 0 of 1730 vertices.
		[0]PCGAMGprolongator_AGG New grid 895 nodes
		[0]PCSetUp_GAMG 2) N=895, n data cols=1, nnz/row (ave)=5, 4 active pes
	[0]scaleFilterGraph 91.3043% nnz after filtering, with threshold 0.05, 5.54359 nnz ave.
	[0]maxIndSetAgg removed 0 of 195 vertices.
		[0]PCGAMGprolongator_AGG New grid 139 nodes
	[0]createLevel aggregate processors: npe: 4 --> 1, neq=139
		[0]PCSetUp_GAMG 3) N=139, n data cols=1, nnz/row (ave)=4, 1 active pes
	[0]PCSetUp_GAMG 4 levels, grid compexity = 1.15398
			PCSetUp_GAMG PC setup max eigen=1.875451e+00 min=2.696859e-02
			PCSetUp_GAMG PC setup max eigen=1.742779e+00 min=1.770445e-02
			PCSetUp_GAMG PC setup max eigen=1.948789e+00 min=3.955759e-02
  Residual norms for pres_ solve.
  0 KSP Residual norm 5.141026204165e+03
  2 KSP Residual norm 1.284239020662e+03
  4 KSP Residual norm 9.967668419130e+02
  6 KSP Residual norm 5.783283077358e+02
  8 KSP Residual norm 5.566458446657e+02
 10 KSP Residual norm 3.783499634403e+02
 12 KSP Residual norm 3.053155044665e+02
 14 KSP Residual norm 2.726314646644e+02
 16 KSP Residual norm 1.960952298636e+02
 18 KSP Residual norm 1.865981998220e+02
 20 KSP Residual norm 1.554042318839e+02
 22 KSP Residual norm 1.497631349479e+02
 24 KSP Residual norm 4.598812937768e+02
 26 KSP Residual norm 1.678435395838e+02
 28 KSP Residual norm 2.040759429929e+02
 30 KSP Residual norm 2.288608663089e+02
 32 KSP Residual norm 2.733802693469e+02
 34 KSP Residual norm 1.640058147647e+02
 36 KSP Residual norm 1.172045953032e+02
 38 KSP Residual norm 1.157357240159e+02
 40 KSP Residual norm 1.122520337943e+02
 42 KSP Residual norm 9.825251767781e+01
 44 KSP Residual norm 1.208285004589e+02
 46 KSP Residual norm 6.786930614669e+01
 48 KSP Residual norm 4.590732680097e+01
 50 KSP Residual norm 3.841598045058e+01
 52 KSP Residual norm 2.625665852109e+01
 54 KSP Residual norm 1.941467729850e+01
 56 KSP Residual norm 1.365056340101e+01
 58 KSP Residual norm 6.773865959980e+00
 60 KSP Residual norm 5.087803263599e+00
 62 KSP Residual norm 4.056350834310e+00
 64 KSP Residual norm 2.885709078944e+00
 66 KSP Residual norm 3.319001782669e+00
 68 KSP Residual norm 2.786670792779e+00
 70 KSP Residual norm 5.516775828892e+00
 72 KSP Residual norm 4.496277080798e+00
 74 KSP Residual norm 1.004981312474e-01
 76 KSP Residual norm 5.360056134540e-02
 78 KSP Residual norm 4.464985177773e-02
 80 KSP Residual norm 3.483114821741e-02
 82 KSP Residual norm 1.514538931552e-02
 84 KSP Residual norm 1.223770508292e-02
 86 KSP Residual norm 1.423206397892e-02
 88 KSP Residual norm 9.108998551955e-03
 90 KSP Residual norm 7.266553500351e-03
 92 KSP Residual norm 9.600829160875e-04
 94 KSP Residual norm 2.730957811323e-04
 96 KSP Residual norm 1.481227697383e-04
 98 KSP Residual norm 8.426581071258e-05
100 KSP Residual norm 7.380041287915e-05
102 KSP Residual norm 5.553587538116e-05
104 KSP Residual norm 4.563527252379e-05
106 KSP Residual norm 3.110759145615e-05
108 KSP Residual norm 1.785372995034e-05
110 KSP Residual norm 1.720065891767e-05
112 KSP Residual norm 1.213804492876e-05
114 KSP Residual norm 2.835812681505e-05
116 KSP Residual norm 8.426402773025e-06
118 KSP Residual norm 3.833374276573e-06
120 KSP Residual norm 4.812273681701e-06
122 KSP Residual norm 1.117614658717e-06
124 KSP Residual norm 7.404391742242e-07
126 KSP Residual norm 5.129803443305e-07
128 KSP Residual norm 4.260359119617e-07
130 KSP Residual norm 4.109770534864e-07
132 KSP Residual norm 5.183915037437e-07
134 KSP Residual norm 1.091650015290e-06
136 KSP Residual norm 1.271770801341e-07
138 KSP Residual norm 2.534603085234e-08
140 KSP Residual norm 2.290908824239e-08
142 KSP Residual norm 5.846953963288e-09
KSP Object:(pres_) 4 MPI processes
  type: bcgsl
    BCGSL: Ell = 2
    BCGSL: Delta = 0
  maximum iterations=5000
  tolerances:  relative=1e-12, absolute=1e-50, divergence=10000
  left preconditioning
  diagonally scaled system
  has attached null space
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object:(pres_) 4 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (pres_mg_coarse_)     4 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (pres_mg_coarse_)     4 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 4
        Local solve info for each block is in the following KSP and PC objects:
      [0] number of local blocks = 1, first local block number = 0
        [0] local block number 0
        KSP Object:        (pres_mg_coarse_sub_)         1 MPI processes
          type: preonly
          maximum iterations=10000, initial guess is zero
        PC Object:        (pres_mg_coarse_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 1.66568
              Factored matrix follows:
                Matrix Object:                 1 MPI processes
                  type: seqaij
                  rows=139, cols=139
                  package used to perform factorization: petsc
                  total: nonzeros=1131, allocated nonzeros=1131
                  total number of mallocs used during MatSetValues calls =0
                    not using I-node routines
          linear system matrix = precond matrix:
            type: seqaij
            rows=139, cols=139
            total: nonzeros=679, allocated nonzeros=679
      [1] number of local blocks = 1, first local block number = 1
        [1] local block number 0
          type: preonly
          type: lu
            matrix ordering: nd
            factor fill ratio given 5, needed 0
                  type: seqaij
                  rows=0, cols=0
                  total: nonzeros=1, allocated nonzeros=1
            type: seqaij
            rows=0, cols=0
            total: nonzeros=0, allocated nonzeros=0
      [2] number of local blocks = 1, first local block number = 2
        [2] local block number 0
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
                  rows=0, cols=0
            type: seqaij
            rows=0, cols=0
      [3] number of local blocks = 1, first local block number = 3
        [3] local block number 0
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
                  rows=0, cols=0
            type: seqaij
            rows=0, cols=0
      Matrix Object:       4 MPI processes
        type: mpiaij
        rows=139, cols=139
          not using I-node (on process 0) routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (pres_mg_levels_1_)     4 MPI processes
      type: richardson
        Richardson: damping factor=1
    PC Object:    (pres_mg_levels_1_)     4 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: mpiaij
        rows=895, cols=895
        total: nonzeros=4941, allocated nonzeros=4941
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (pres_mg_levels_2_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_2_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=7604, cols=7604
        total: nonzeros=49366, allocated nonzeros=49366
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (pres_mg_levels_3_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_3_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=58507, cols=58507
        total: nonzeros=383336, allocated nonzeros=675924
    type: mpiaij
