[petsc-users] GAMG issue
Jed Brown
jedbrown at mcs.anl.gov
Wed Mar 14 13:44:04 CDT 2012
On Wed, Mar 14, 2012 at 13:38, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Damn, I'm not preallocating the graph perfectly for unsymmetric matrices
> and PETSc now dies on this.
> I have a fix but I committed it with other changes that I do not want to
> commit. The changes are all in one file so I should be able to just commit
> this file.
> Anyone know how to delete a commit?
Be careful to make a backup.
Edit your ~/.hgrc
[extensions]
mq =
crecord = ~/src/crecord/crecord
For partial commits, I use this kinda clunky non-standard extension because
I don't know of anything better for Hg.
hg clone https://bitbucket.org/edgimar/crecord ~/src/crecord
Then you can "hg crecord" which will let you select specific lines to
commit.
> I've tried:
> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg strip 22487:26ffb9eef17f
> hg: unknown command 'strip'
> 'strip' is provided by the following extension:
> mq manage a stack of patches
> use "hg help extensions" for information on enabling extensions
> But have not figured out how to load extensions.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120314/d01eb1a5/attachment.htm>
