[petsc-users] [petsc-maint #107932] run a simple example ex19 in src/snes/examples/tutorials
Paul Mullowney
paulm at txcorp.com
Tue Mar 13 10:44:02 CDT 2012
Sorry.
You are asking for Jacobi, and not BJacobi.
D'oh!
-Paul
> In bjacobi.c, the following comments are given for PCCreate_BJacobi.
> Developer Notes: This preconditioner does not currently work with
> CUDA/CUSP for a couple of reasons.
> (1) It creates seq vectors as work vectors that should be cusp
> (2) The use of VecPlaceArray() is not handled properly by CUSP (that
> is it will not know where the ownership of the vector is so may use
> wrong values) even if it did know the ownership it may induce extra
> copy ups and downs. Satish suggests a VecTransplantArray() to handle
> two vectors sharing the same pointer and handling the CUSP side as
> well instead of VecGetArray()/VecPlaceArray().
> I've had some success with comment (2) above in regards to Singleblock
> BJacobi. I haven't yet tried it for Multiblock or Multiproc.
> -Paul
>> On Tue, Mar 13, 2012 at 10:18, Paul Mullowney <paulm at txcorp.com
>> <mailto:paulm at txcorp.com>> wrote:
>> I don't think PCJACOBI is working on the GPU yet.
>> It damn well better be.
>> (It only calls MatGetDiagonal(), everything else is just a Vec
>> operation and the VecType will be set so that it runs on the GPU.)
>> I have some local fixes to make it work efficiently (without
>> extra copies), but changes won't be pushed too soon because the
>> design is not sufficiently general.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120313/42ffb2ae/attachment.htm>
