[petsc-users] [petsc-maint #107932] run a simple example ex19 in src/snes/examples/tutorials
Xiangze Zeng
zengshixiangze at 163.com
Tue Mar 13 09:30:15 CDT 2012
Hi, Jed.
I do set preallocation after setting the matrix type.
Zeng
在 2012-03-13 22:14:12,"Jed Brown" <jedbrown at mcs.anl.gov> 写道:
2012/3/13 Xiangze Zeng <zengshixiangze at 163.com>
At the beginning and end of the codes for setting the matrices values, I add "printf", and compute the time of this period. It is much longer than that when I don't use the GPU. I just guess the time is used for copping data. My PCTYPE is sor. And 2000 iterations. Do you have any suggestion about this?
I suspect you have lost preallocation information when the matrix type was changed. Make sure you set preallocation after setting the matrix type.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120313/54906b68/attachment.htm>
