[petsc-users] Creating a dll on 64-bit environment
Markus Iivonen
Markus.Iivonen at metropolia.fi
Sat Mar 10 11:49:33 CST 2012
Hello,
I've written a program on 32-bit environment and I want to use a dll. Everything worked fine until I uploaded the code on the other machine which run 64-bit os.
At first I got an error:
"/usr/bin/ld: MyClass.o: relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
MyClass.o: could not read symbols: Bad value"
what was new for me because I haven't worked on 64bit environment before. Anyway at first I just tried to modify "-${CLINKER} -shared -Wl,-soname,${SONAME} -o ${VERS} *.o ${PETSC_MAT_LIB}" as "-${CLINKER} -shared -fPIC -Wl,-soname,${SONAME} -o ${VERS} *.o ${PETSC_MAT_LIB}"
even after that I got the same error, after that I added -fPIC to CFLAGS and the error changed:
"../petsc/petsc-3.2-p6/arch-linux2-cxx-debug/lib/libpetsc.a(err.o): relocation R_X86_64_32 against `ompi_mpi_comm_self' can not be used when making a shared object; recompile with -fPIC"
So here is my current makefile
CFLAGS = - fPIC
CCPPFLAGS =
LOCDIR = /home/user/petsc/project/
EXAMPLESC = x1.cpp x2.cpp x3.cpp
PETSC_DIR = /home/user/petsc/petsc-3.2-p6/
MYLIB = -L/home/user/petsc/project/opt/lib/ -libmyclass
LIBADD = /.../user/petsc/project/opt/lib/
VERS = libmyclass.so.1.0
SONAME = libmyclass.so.1
SOWOV = libmyclass.so
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
MyProgram: main.o chkopts
-${CLINKER} -o $@ $< ${MYLIB} ${PETSC_MAT_LIB}
${RM} main.o
export LD_LIBRARY_PATH=${LIBADD}:$LD_LIBRARY_PATH
LibMyProgram.so: MyClass.o chkopts
mv ${VERS} ${LIBADD}
ln -sf ${LIBADD}${VERS} ${LIBADD}${SOWOV}
ln -sf ${LIBADD}${VERS} ${LIBADD}${SONAME}
So would there be any kind of solution to this problem ?
Thank You.
Sincerely Markus Iivonen
