[petsc-users] Projection preconditioner as PCMG
    Abdul Hanan Sheikh
    hanangul12 at yahoo.co.uk
    Fri Mar  9 05:16:01 CST 2012
Dear,
To my earlier querry:
What if I want to approximate my all coarse matrices with any Krylov iteration ?
reply:
The methods on each
level are independent, you can set them with -mg_coarse_ksp_type gmres
-mg_levels_1_ksp_type cg -mg_levels_1_ksp_max_it 100
-mg_levels_2_ksp_type minres ...
This command line option changes the ksp_type on both ksp_pre and ksp_post (pre and post smoothing) .
Where as I need to fix the ksp_post_type as RICHARDSON to get my Prec = C + I - AC ;
If adapt pre_smoother as follows :
ierr = MGGetSmootherDown(pcmg,lev,&ksp_pre); CHKERRQ(ierr);
ierr = KSPSetType(ksp_pre, KSPGMRES);CHKERRQ(ierr);
Does ONLY setting pre_smoother as GMRES means that GMRES iterates on coarse matrix at level = lev ?
Thanks in advance.
Abdul.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120309/a44ed591/attachment.htm>
