[petsc-users] Problem with KSPSetOperators
    Hong Zhang
    hzhang at mcs.anl.gov
    Fri Mar  2 09:13:07 CST 2012
Manfred :
Thanks for sending the modified code. I can repeat the error in
'MatFactorNumeric_MUMPS'.
Running it with '-mat_type aij' works well, likely there is a bug in our
code.
I'll work on it and get back to you about the fix.
Meanwhile, you may use aij format instead of sbaij.
Hong
> Jed Brown schrieb:
> On Fri, Mar 2, 2012 at 04:18, Manfred Gratt <manfred.gratt at uibk.ac.at>wrote:
>> thank you for your quick response. The petsc-dev did not solve the
>> segfault. I checked what the difference from ex5 to my code was and after I
>> changed my code to ex5 the segfault was gone when I used MatZeroEntries
>> instead of destroying and creating a new Matrix for the second solve.  This
>> seems to be logical but, what I do not understand is why it works with
>> destroying and creating a new Matrix on more than one processor fine?
>  I can't understand from this description exactly what works and what
> doesn't work for you. There shouldn't be a SEGV for any "reasonable"
> sequence of calls you make, so we should clarify the confusion and either
> fix the bug or make a better/earlier error message.
> Is there a way you can modify ex5 (or another example, or send your own
> code) to show the problem?
> I tried to change the ex5 to bring the same error but I am not able to get
> the same error. I still get an error although it is an error I don't
> understand.
> I changed ex5 to calculate in second solve the same matrix as in the first
> solve. As written in definition of SAME_NONZERO_PATTERN it should work.
> When before the second solve the matrix C is set to zero with
> MatZeroEntries it works well, but when I instead destroy the matrix C and
> create a new C it does not work with the error that it is an Numerically
> singular matrix. Should that happen? It is the same matrix as in the first
> solve. So shouldnt it happen there?
> When I use instead DIFFERENT_NONZERO_PATTERN it also works well in the
> second solve.
> I modified the ex5 so that you can easily call the changes with
> -mat_zeroent to call MatZeroEntries instead of destroy and create a new
> matrix.
> The second option -mat_different calls DIFFERENT_NONZERO_PATTERN instead
> of SAME_NONZERO_PATTERN.
> Without these options it throws an error when you call it with
> ./ex5 -ksp_monitor -mat_type sbaij -pc_type cholesky
> -pc_factor_mat_solver_package mumps
> Thanks
> Manfred
> newex5.c:
> static char help[] = "Solves two linear systems in parallel with KSP.  The
> code\n\
> illustrates repeated solution of linear systems with the same
> preconditioner\n\
> method but different matrices (having the same nonzero structure).  The
> code\n\
> also uses multiple profiling stages.  Input arguments are\n\
>   -m <size> : problem size\n\
>   -mat_nonsym : use nonsymmetric matrix (default is symmetric)\n\n";
> /*T
>    Concepts: KSP^repeatedly solving linear systems;
>    Concepts: PetscLog^profiling multiple stages of code;
>    Processors: n
> T*/
>   Include "petscksp.h" so that we can use KSP solvers.  Note that this file
>   automatically includes:
>      petscsys.h       - base PETSc routines   petscvec.h - vectors
>      petscmat.h - matrices
>      petscis.h     - index sets            petscksp.h - Krylov subspace
> methods
>      petscviewer.h - viewers               petscpc.h  - preconditioners
> #include <petscksp.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
>   KSP            ksp;              /* linear solver context */
>   Mat            C;                /* matrix */
>   Vec            x,u,b;            /* approx solution, RHS, exact solution
>   PetscReal      norm;             /* norm of solution error */
>   PetscScalar    v,none = -1.0;
>   PetscInt       Ii,J,ldim,low,high,iglobal,Istart,Iend;
>   PetscErrorCode ierr;
>   PetscInt       i,j,m = 3,n = 2,its;
>   PetscMPIInt    size,rank;
>   PetscBool      mat_nonsymmetric = PETSC_FALSE;
>   PetscBool      matzeroent = PETSC_FALSE, different_pattern = PETSC_FALSE;
> #if defined (PETSC_USE_LOG)
>   PetscLogStage  stages[2];
> #endif
>   PetscInitialize(&argc,&args,(char *)0,help);
>   ierr = PetscOptionsGetInt(PETSC_NULL,"-m",&m,PETSC_NULL);CHKERRQ(ierr);
>   ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
>   ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
>   n = 2*size;
>      Set flag if we are doing a nonsymmetric problem; the default is
> symmetric.
>   ierr =
> PetscOptionsGetBool(PETSC_NULL,"-mat_nonsym",&mat_nonsymmetric,PETSC_NULL);CHKERRQ(ierr);
>   ierr =
> PetscOptionsGetBool(PETSC_NULL,"-mat_zeroent",&matzeroent,PETSC_NULL);CHKERRQ(ierr);
>   ierr =
> PetscOptionsGetBool(PETSC_NULL,"-mat_different",&different_pattern,PETSC_NULL);CHKERRQ(ierr);
>      Register two stages for separate profiling of the two linear solves.
>      Use the runtime option -log_summary for a printout of performance
>      statistics at the program's conlusion.
>   ierr = PetscLogStageRegister("Original Solve",&stages[0]);CHKERRQ(ierr);
>   ierr = PetscLogStageRegister("Second Solve",&stages[1]);CHKERRQ(ierr);
>   /* -------------- Stage 0: Solve Original System ----------------------
>      Indicate to PETSc profiling that we're beginning the first stage
>   ierr = PetscLogStagePush(stages[0]);CHKERRQ(ierr);
>      Create parallel matrix, specifying only its global dimensions.
>      When using MatCreate(), the matrix format can be specified at
>      runtime. Also, the parallel partitioning of the matrix is
>      determined by PETSc at runtime.
>   ierr = MatCreate(PETSC_COMM_WORLD,&C);CHKERRQ(ierr);
>   ierr = MatSetSizes(C,PETSC_DECIDE,PETSC_DECIDE,m*n,m*n);CHKERRQ(ierr);
>   ierr = MatSetFromOptions(C);CHKERRQ(ierr);
>   ierr = MatSetUp(C);CHKERRQ(ierr);
>      Currently, all PETSc parallel matrix formats are partitioned by
>      contiguous chunks of rows across the processors.  Determine which
>      rows of the matrix are locally owned.
>   ierr = MatGetOwnershipRange(C,&Istart,&Iend);CHKERRQ(ierr);
>      Set matrix entries matrix in parallel.
>       - Each processor needs to insert only elements that it owns
>         locally (but any non-local elements will be sent to the
>         appropriate processor during matrix assembly).
>       - Always specify global row and columns of matrix entries.
>   for (Ii=Istart; Ii<Iend; Ii++) {
>     v = -1.0; i = Ii/n; j = Ii - i*n;
>     if (i>0)   {J = Ii - n; ierr =
> MatSetValues(C,1,&Ii,1,&J,&v,ADD_VALUES);CHKERRQ(ierr);}
>     if (i<m-1) {J = Ii + n; ierr =
>     if (j>0)   {J = Ii - 1; ierr =
>     if (j<n-1) {J = Ii + 1; ierr =
>     v = 4.0; ierr = MatSetValues(C,1,&Ii,1,&Ii,&v,ADD_VALUES);
>      Make the matrix nonsymmetric if desired
>    if (mat_nonsymmetric) {
>        v = -1.5; i = Ii/n;
>        if (i>1)   {J = Ii-n-1; ierr =
>    } else {
>     ierr = MatSetOption(C,MAT_SYMMETRIC,PETSC_TRUE);CHKERRQ(ierr);
>     ierr = MatSetOption(C,MAT_SYMMETRY_ETERNAL,PETSC_TRUE);CHKERRQ(ierr);
>      Assemble matrix, using the 2-step process:
>        MatAssemblyBegin(), MatAssemblyEnd()
>      Computations can be done while messages are in transition
>      by placing code between these two statements.
>   ierr = MatAssemblyBegin(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>   ierr = MatAssemblyEnd(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>      Create parallel vectors.
>       - When using VecSetSizes(), we specify only the vector's global
>         dimension; the parallel partitioning is determined at runtime.
>       - Note: We form 1 vector from scratch and then duplicate as needed.
>   ierr = VecCreate(PETSC_COMM_WORLD,&u);CHKERRQ(ierr);
>   ierr = VecSetSizes(u,PETSC_DECIDE,m*n);CHKERRQ(ierr);
>   ierr = VecSetFromOptions(u);CHKERRQ(ierr);
>   ierr = VecDuplicate(u,&b);CHKERRQ(ierr);
>   ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>      Currently, all parallel PETSc vectors are partitioned by
>      contiguous chunks across the processors.  Determine which
>      range of entries are locally owned.
>   ierr = VecGetOwnershipRange(x,&low,&high);CHKERRQ(ierr);
>     Set elements within the exact solution vector in parallel.
>        locally (but any non-local entries will be sent to the
>        appropriate processor during vector assembly).
>      - Always specify global locations of vector entries.
>   ierr = VecGetLocalSize(x,&ldim);CHKERRQ(ierr);
>    for (i=0; i<ldim; i++) {
>      iglobal = i + low;
>      v = (PetscScalar)(i + 100*rank);
>      ierr = VecSetValues(u,1,&iglobal,&v,INSERT_VALUES);CHKERRQ(ierr);
>      Assemble vector, using the 2-step process:
>        VecAssemblyBegin(), VecAssemblyEnd()
>      Computations can be done while messages are in transition,
>   ierr = VecAssemblyBegin(u);CHKERRQ(ierr);
>   ierr = VecAssemblyEnd(u);CHKERRQ(ierr);
>      Compute right-hand-side vector
>   ierr = MatMult(C,u,b);CHKERRQ(ierr);
>     Create linear solver context
>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>      Set operators. Here the matrix that defines the linear system
>      also serves as the preconditioning matrix.
>   if(different_pattern) {
>     ierr =
> KSPSetOperators(ksp,C,C,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
>   }else {
>     ierr = KSPSetOperators(ksp,C,C,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
>      Set runtime options (e.g., -ksp_type <type> -pc_type <type>)
>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>      Solve linear system.  Here we explicitly call KSPSetUp() for more
>      detailed performance monitoring of certain preconditioners, such
>      as ICC and ILU.  This call is optional, as KSPSetUp() will
>      automatically be called within KSPSolve() if it hasn't been
>      called already.
>   ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>      Check the error
> //   ierr = VecAXPY(x,none,u);CHKERRQ(ierr);
> //   ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
> //   ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
> //   if (norm > 1.e-13){
> //     ierr = PetscPrintf(PETSC_COMM_WORLD,"Norm of error %G, Iterations
> %D\n",norm,its);CHKERRQ(ierr);
>   /* -------------- Stage 1: Solve Second System ---------------------- */
>      Solve another linear system with the same method.  We reuse the KSP
>      context, matrix and vector data structures, and hence save the
>      overhead of creating new ones.
>      Indicate to PETSc profiling that we're concluding the first
>      stage with PetscLogStagePop(), and beginning the second stage with
>      PetscLogStagePush().
>   ierr = PetscLogStagePop();CHKERRQ(ierr);
>   ierr = PetscLogStagePush(stages[1]);CHKERRQ(ierr);
>      Initialize all matrix entries to zero.  MatZeroEntries() retains the
>      nonzero structure of the matrix for sparse formats.
>   if(matzeroent) {
>     ierr = MatZeroEntries(C);CHKERRQ(ierr);
>   } else {
>     ierr = MatDestroy(&C);
>      Assemble matrix again.  Note that we retain the same matrix data
>      structure and the same nonzero pattern; we just change the values
>      of the matrix entries.
>        v = -1.5; i = Ii/n;
>   } else {
>      Compute another right-hand-side vector
>       - The flag SAME_NONZERO_PATTERN indicates that the
>         preconditioning matrix has identical nonzero structure
>         as during the last linear solve (although the values of
>         the entries have changed). Thus, we can save some
>         work in setting up the preconditioner (e.g., no need to
>         redo symbolic factorization for ILU/ICC preconditioners).
>       - If the nonzero structure of the matrix is different during
>         the second linear solve, then the flag DIFFERENT_NONZERO_PATTERN
>         must be used instead.  If you are unsure whether the
>         matrix structure has changed or not, use the flag
>         DIFFERENT_NONZERO_PATTERN.
>       - Caution:  If you specify SAME_NONZERO_PATTERN, PETSc
>         believes your assertion and does not check the structure
>         of the matrix.  If you erroneously claim that the structure
>         is the same when it actually is not, the new preconditioner
>         will not function correctly.  Thus, use this optimization
>         feature with caution!
>     ierr =
>   }else {
>      Solve linear system
>      Check the error
>   if (norm > 1.e-4){
>      Free work space.  All PETSc objects should be destroyed when they
>      are no longer needed.
>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>   ierr = VecDestroy(&u);CHKERRQ(ierr);
>   ierr = VecDestroy(&x);CHKERRQ(ierr);
>   ierr = VecDestroy(&b);CHKERRQ(ierr);
>   ierr = MatDestroy(&C);CHKERRQ(ierr);
>      Indicate to PETSc profiling that we're concluding the second stage
>   ierr = PetscFinalize();
>   return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120302/c1c8cb15/attachment-0001.htm>
