[petsc-users] error of AODestroy and ISLocalToGlobalMappingDestroy
Hui Zhang
mike.hui.zhang at hotmail.com
Fri Mar 2 08:55:00 CST 2012
> Hi,
> I got errors on a linux cluster from AODestroy and ISLocalToGlobalMappingDestroy with
> the petsc-dev hg version 882fc279ddfaa44915c56a5b227514ada881775d. And if I run the
> following test program with number of processes > 3, it hangs on. The linux is using mpich2.
> #include <petscao.h>
> char help[]= "test ao destroy\n";
> int main(int argc, char **argv)
> AO ao;
> PetscInitialize(&argc,&argv,PETSC_NULL,help);
> AOCreate(PETSC_COMM_WORLD,&ao);
> AODestroy(&ao);
> PetscFinalize();
> return 0;
Sorry, I just have changed the order in the hosts file and then it runs ok and
will not hang. So it must be some place wrong in my actual computing programs.
I will check again.
> I also run the same program with petsc-3.2 on my Mac, if I use mpirun it is ok
> but if I use mpiexec it gives the same error. The mac is using openmpi.
> Thank you!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120302/b536f411/attachment.htm>
