[petsc-users] how is PETSC_MAX_PATH_LEN defined?
Ju LIU
liujuy at gmail.com
Thu Mar 1 16:15:34 CST 2012
All right. Thanks, Satish!
Ju
2012/3/1 Satish Balay <balay at mcs.anl.gov>
> from include/petscsys.h
> #if defined(PETSC_HAVE_LIMITS_H)
> #include <limits.h>
> #endif
> #if defined(PETSC_HAVE_SYS_PARAM_H)
> #include <sys/param.h>
> #endif
> #if defined(PETSC_HAVE_SYS_TYPES_H)
> #include <sys/types.h>
> #endif
> #if defined(MAXPATHLEN)
> # define PETSC_MAX_PATH_LEN MAXPATHLEN
> #elif defined(MAX_PATH)
> # define PETSC_MAX_PATH_LEN MAX_PATH
> #elif defined(_MAX_PATH)
> # define PETSC_MAX_PATH_LEN _MAX_PATH
> #else
> # define PETSC_MAX_PATH_LEN 4096
> #endif
> So usually the value is picked up from system include files via
> MAXPATHLEN etc - and if no value is found - it it set as 4096.
> Satish
> On Thu, 1 Mar 2012, Ju LIU wrote:
> > Hi:
> > I am reading
> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex9.c.html
> > I am curious about the value of PETSC_MAX_PATH_LEN.
> > Thanks,
> > Ju
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/aa8f65ac/attachment.htm>
