[petsc-users] Number of Matrices with -snes_mf and -snes_mf_operator
Derek Gaston friedmud at gmail.com
Thu Mar 1 10:16:41 CST 2012
In trying to track down where all of our memory usage is coming from I
noticed that PETSc is saying that more matrices than I expect are getting
created.  For instance, with -snes_mf I would expect to see just one matrix
(we always create one, even with -snes_mf)... but instead I'm seeing 2
(from -log_summary):
              Matrix     2              2   1634161540     0
Then when using -snes_mf_operator with ilu as the preconditioner I'm
actually seeing _3_!
              Matrix     3              3   3080557036     0
As you can see, our matrices are fairly heavy (cubic hermites in 3d have a
heavy sparsity pattern) so it would be awesome to keep the number of them
down.  I've double checked that we're not calling MatCreate more than once
in our code.  So is this expected behavior or am I doing something wrong
somewhere else?  What's the best way to track this down... maybe print a
stack trace inside MatCreate?
Particulars:
PETSc 3.1-p8 (yes yes old... ;-)
Using it through libMesh
Derek
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/705cf53d/attachment.htm>
