[petsc-users] Save matrix view to postscript?
Tue Jul 31 18:20:37 CDT 2012
On Tue, Jul 31, 2012 at 4:13 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
> Thanks!
> I can't seem to get it to work though.
> When I configure --with-afterimage it says that I need to download it.
> When I use --download-afterimage it says:
> "External package afterimage does not support --download-afterimage"
> I am using a MAC with OS X.   Where can I download afterimage?
http://www.afterstep.org/afterimage/
> Also, in general, if I want to add a configure to petsc with ./configure,
> do I have to run ./configure with ALL my options, or just with the new ones
> I want to add/change?  Will it save my previous configure?
Run $PETSC_ARCH/conf/reconfigure-*.py --new-options
>  Thanks again for your rapid responses!
>  - Ron C
> On Tue, Jul 31, 2012 at 3:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Sorry the postscript never really worked and then the world went PDF.
>>   You can do what you want in PETSc 3.3 with
>>     ierr = PetscOptionsBool("-draw_save_movie","Make a movie from the
>> images saved","PetscDrawSetSave",movie,&movie,PETSC_NULL);CHKERRQ(ierr);
>>     ierr = PetscOptionsString("-draw_save","Save graphics to
>> file","PetscDrawSetSave",filename,filename,PETSC_MAX_PATH_LEN,&save);CHKERRQ(ierr);
>> /*@C
>>    PetscDrawSave - Saves images produced in a PetscDraw into a file as a
>> Gif file using AfterImage
>>    Collective on PetscDraw
>>    Input Parameter:
>> +  draw      - the graphics context
>> .  filename  - name of the file, if PETSC_NULL uses name of draw object
>> -  movie - produce a movie of all the images
>>    Options Database Command:
>> +  -draw_save  <filename>
>> -  -draw_save_movie
>>    Level: intermediate
>>    Concepts: X windows^graphics
>>    Concepts: drawing^postscript
>>    Concepts: postscript^graphics
>>    Concepts: drawing^Microsoft Windows
>>    Notes: Requires that PETSc be configured with the option
>> --with-afterimage
>> .seealso: PetscDrawSetFromOptions(), PetscDrawCreate(),
>> PetscDrawDestroy(), PetscDrawSave()
>>   Please report any problems to petsc-maint at mcs.anl.gov
>>   Note that you must make sure the windows being saved are not covered by
>> other windows.
>>    Barry
>> On Jul 31, 2012, at 3:17 PM, "Ronald M. Caplan" <caplanr at predsci.com>
>> wrote:
>> > Hi,
>> > I saw online that back in 2006 there was a way to tell PETSc to save
>> the image in -mat_view_draw into a postscript file.  Is there anyway to
>> still do this?  Or to same the image into any format?  Or to save a movie
>> of the residual images in ksp?
>> > Thanks,
>> > Ron C.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120731/bc867d85/attachment.html>
