[petsc-users] Save matrix view to postscript?
Ronald M. Caplan caplanr at predsci.com
Tue Jul 31 18:13:20 CDT 2012
Thanks!
I can't seem to get it to work though.
When I configure --with-afterimage it says that I need to download it.
When I use --download-afterimage it says:
"External package afterimage does not support --download-afterimage"
I am using a MAC with OS X.   Where can I download afterimage?
Also, in general, if I want to add a configure to petsc with ./configure,
do I have to run ./configure with ALL my options, or just with the new ones
I want to add/change?  Will it save my previous configure?
 Thanks again for your rapid responses!
 - Ron C
On Tue, Jul 31, 2012 at 3:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Sorry the postscript never really worked and then the world went PDF.
>   You can do what you want in PETSc 3.3 with
>     ierr = PetscOptionsBool("-draw_save_movie","Make a movie from the
> images saved","PetscDrawSetSave",movie,&movie,PETSC_NULL);CHKERRQ(ierr);
>     ierr = PetscOptionsString("-draw_save","Save graphics to
> file","PetscDrawSetSave",filename,filename,PETSC_MAX_PATH_LEN,&save);CHKERRQ(ierr);
> /*@C
>    PetscDrawSave - Saves images produced in a PetscDraw into a file as a
> Gif file using AfterImage
>    Collective on PetscDraw
>    Input Parameter:
> +  draw      - the graphics context
> .  filename  - name of the file, if PETSC_NULL uses name of draw object
> -  movie - produce a movie of all the images
>    Options Database Command:
> +  -draw_save  <filename>
> -  -draw_save_movie
>    Level: intermediate
>    Concepts: X windows^graphics
>    Concepts: drawing^postscript
>    Concepts: postscript^graphics
>    Concepts: drawing^Microsoft Windows
>    Notes: Requires that PETSc be configured with the option
> --with-afterimage
> .seealso: PetscDrawSetFromOptions(), PetscDrawCreate(),
> PetscDrawDestroy(), PetscDrawSave()
>   Please report any problems to petsc-maint at mcs.anl.gov
>   Note that you must make sure the windows being saved are not covered by
> other windows.
>    Barry
> On Jul 31, 2012, at 3:17 PM, "Ronald M. Caplan" <caplanr at predsci.com>
> wrote:
> > Hi,
> > I saw online that back in 2006 there was a way to tell PETSc to save the
> image in -mat_view_draw into a postscript file.  Is there anyway to still
> do this?  Or to same the image into any format?  Or to save a movie of the
> residual images in ksp?
> > Thanks,
> > Ron C.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120731/99618538/attachment.html>
