[petsc-users] segfault in MatAssemblyEnd() when using large matrices on multi-core MAC OS-X
Ronald M. Caplan caplanr at predsci.com
Mon Jul 30 17:04:41 CDT 2012
Hi everyone,
I seem to have solved the problem.
I was storing my entire matrix on node 0 and then calling MatAssembly
(begin and end) on all nodes (which should have worked...).
Apparently I was using too much space for the buffering or the like,
because when I change the code so each node sets its own matrix values,
than the MatAssemblyEnd does not seg fault.
Why should this be the case?   How many elements of a vector or matrix can
a single node "set" before Assembly to distribute over all nodes?
 - Ron C
On Fri, Jul 27, 2012 at 2:14 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
> Hi,
> I do not know how to get the stack trace.
> Attached is the code and makefile.
> The value of npts is set to 25 which is where the code crashes with more
> than one core running.   If I set the npts to around 10, then the code
> works with up to 12 processes (fast too!) but no more otherwise there is a
> crash as well.
> Thanks for your help!
>  - Ron C
> On Fri, Jul 27, 2012 at 1:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Jul 27, 2012 at 3:35 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
>>> 1) Checked it, had no leaks or any other problems that I could see.
>>> 2) Ran it with debugging and without.  The debugging is how I know it
>>> was in MatAssemblyEnd().
>> Its rare when valgrind does not catch something, but it happens. From
>> here I would really like:
>>   1) The stack trace from the fault
>>   2) The code to run here
>> This is one of the oldest and most used pieces of PETSc. Its difficult to
>> believe that the bug is there
>> rather than a result of earlier memory corruption.
>>    Thanks,
>>       Matt
>>> 3)  Here is the matrix part of the code:
>>> !Create matrix:
>>>       call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>>       call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N,ierr)
>>>       call MatSetType(A,MATMPIAIJ,ierr)
>>>       call MatSetFromOptions(A,ierr)
>>>       !print*,'3nrt: ',3*nr*nt
>>>       i = 16
>>>       IF(size .eq. 1) THEN
>>>           j = 0
>>>       ELSE
>>>           j = 8
>>>       END IF
>>>       call MatMPIAIJSetPreallocation(A,i,PETSC_NULL_INTEGER,
>>>      &                               j,PETSC_NULL_INTEGER,ierr)
>>>       !Do not call this if using preallocation!
>>>       !call MatSetUp(A,ierr)
>>>       call MatGetOwnershipRange(A,i,j,ierr)
>>>       print*,'Rank ',rank,' has range ',i,' and ',j
>>>       !Get MAS matrix in CSR format (random numbers for now):
>>>       IF (rank .eq. 0) THEN
>>>          call GET_RAND_MAS_MATRIX(CSR_A,CSR_AI,CSR_AJ,nr,nt,np,M)
>>>          print*,'Number of non-zero entries in matrix:',M
>>>           !Store matrix values one-by-one (inefficient:  better way
>>>              !   more complicated - implement later)
>>>          DO i=1,N
>>>            !print*,'numofnonzerosinrowi:',CSR_AJ(i+1)-CSR_AJ(i)+1
>>>             DO j=CSR_AJ(i)+1,CSR_AJ(i+1)
>>>                call MatSetValue(A,i-1,CSR_AI(j),CSR_A(j),
>>>      &                               INSERT_VALUES,ierr)
>>>             END DO
>>>          END DO
>>>          print*,'Done setting matrix values...'
>>>       END IF
>>>       !Assemble matrix A across all cores:
>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>>       print*,'between assembly'
>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>> A couple things to note:
>>> a) my CSR_AJ is what most peaople would call ai etc
>>> b) my CSR array values are 0-index but the arrays are 1-indexed.
>>> Here is the run with one processor (-n 1):
>>> sumseq:PETSc sumseq$ valgrind mpiexec -n 1 ./petsctest -mat_view_info
>>> ==26297== Memcheck, a memory error detector
>>> ==26297== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al.
>>> ==26297== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright
>>> info
>>> ==26297== Command: mpiexec -n 1 ./petsctest -mat_view_info
>>> ==26297==
>>> UNKNOWN task message [id 3403, to mach_task_self(), reply 0x2803]
>>>  N:        46575
>>>  cores:            1
>>>  MPI TEST:  My rank is:           0
>>>  Rank            0  has range            0  and        46575
>>>  Number of non-zero entries in matrix:      690339
>>>  between assembly
>>> Matrix Object: 1 MPI processes
>>>   type: mpiaij
>>>   rows=46575, cols=46575
>>>   total: nonzeros=690339, allocated nonzeros=745200
>>>   total number of mallocs used during MatSetValues calls =0
>>>     not using I-node (on process 0) routines
>>>  PETSc y=Ax time:      367.9164     nsec/mp.
>>>  PETSc y=Ax flops:    0.2251188     GFLOPS.
>>> ==26297==
>>> ==26297== HEAP SUMMARY:
>>> ==26297==     in use at exit: 139,984 bytes in 65 blocks
>>> ==26297==   total heap usage: 938 allocs, 873 frees, 229,722 bytes
>>> allocated
>>> ==26297==
>>> ==26297== LEAK SUMMARY:
>>> ==26297==    definitely lost: 0 bytes in 0 blocks
>>> ==26297==    indirectly lost: 0 bytes in 0 blocks
>>> ==26297==      possibly lost: 0 bytes in 0 blocks
>>> ==26297==    still reachable: 139,984 bytes in 65 blocks
>>> ==26297==         suppressed: 0 bytes in 0 blocks
>>> ==26297== Rerun with --leak-check=full to see details of leaked memory
>>> ==26297==
>>> ==26297== For counts of detected and suppressed errors, rerun with: -v
>>> ==26297== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 1 from 1)
>>> Here is the run with 2 processors (-n 2)
>>> sumseq:PETSc sumseq$ valgrind mpiexec -n 2 ./petsctest -mat_view_info
>>> ==26301== Memcheck, a memory error detector
>>> ==26301== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al.
>>> ==26301== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright
>>> info
>>> ==26301== Command: mpiexec -n 2 ./petsctest -mat_view_info
>>> ==26301==
>>>  N:        46575
>>>  cores:            2
>>>  MPI TEST:  My rank is:           1
>>>  Rank            0  has range            0  and        23288
>>>  Rank            1  has range        23288  and        46575
>>>  between assembly
>>>  between assembly
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [1]PETSC ERROR: or see
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>> corruption errors
>>> [1]PETSC ERROR: likely location of problem given in stack below
>>> [1]PETSC ERROR: ---------------------  Stack Frames
>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [1]PETSC ERROR:       INSTEAD the line number of the start of the
>>> function
>>> [1]PETSC ERROR:       is given.
>>> [1]PETSC ERROR: [1] MatStashScatterGetMesg_Private line 609
>>> /usr/local/petsc-3.3-p2/src/mat/utils/matstash.c
>>> [1]PETSC ERROR: [1] MatAssemblyEnd_MPIAIJ line 646
>>> /usr/local/petsc-3.3-p2/src/mat/impls/aij/mpi/mpiaij.c
>>> [1]PETSC ERROR: [1] MatAssemblyEnd line 4857
>>> /usr/local/petsc-3.3-p2/src/mat/interface/matrix.c
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Signal received!
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13
>>> 15:42:00 CDT 2012
>>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [1]PETSC ERROR: See docs/index.html for manual pages.
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: ./petsctest on a arch-darw named sumseq.predsci.com by
>>> sumseq Fri Jul 27 13:34:36 2012
>>> [1]PETSC ERROR: Libraries linked from
>>> /usr/local/petsc-3.3-p2/arch-darwin-c-debug/lib
>>> [1]PETSC ERROR: Configure run at Fri Jul 27 13:28:26 2012
>>> [1]PETSC ERROR: Configure options --with-debugging=1
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: User provided function() line 0 in unknown directory
>>> unknown file
>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
>>> [cli_1]: aborting job:
>>> ==26301==
>>> ==26301== HEAP SUMMARY:
>>> ==26301==     in use at exit: 139,984 bytes in 65 blocks
>>> ==26301==   total heap usage: 1,001 allocs, 936 frees, 234,886 bytes
>>> allocated
>>> ==26301==
>>> ==26301== LEAK SUMMARY:
>>> ==26301==    definitely lost: 0 bytes in 0 blocks
>>> ==26301==    indirectly lost: 0 bytes in 0 blocks
>>> ==26301==      possibly lost: 0 bytes in 0 blocks
>>> ==26301==    still reachable: 139,984 bytes in 65 blocks
>>> ==26301==         suppressed: 0 bytes in 0 blocks
>>> ==26301== Rerun with --leak-check=full to see details of leaked memory
>>> ==26301==
>>> ==26301== For counts of detected and suppressed errors, rerun with: -v
>>> ==26301== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 1 from 1)
>>>  - Ron
>>> On Fri, Jul 27, 2012 at 1:19 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> 1. Check for memory leaks using Valgrind.
>>>> 2. Be sure to run --with-debugging=1 (the default) when trying to find
>>>> the error.
>>>> 3. Send the full error message and the relevant bit of code.
>>>> On Fri, Jul 27, 2012 at 3:17 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
>>>>> Hello,
>>>>> I am running a simple test code which takes a sparse AIJ matrix in
>>>>> PETSc and multiplies it by a vector.
>>>>> The matrix is defined as an AIJ MPI matrix.
>>>>> When I run the program on a single core, it runs fine.
>>>>> When I run it using MPI with multiple threads (I am on a 4-core,
>>>>> 8-thread MAC) I can get the code to run correctly for matrices under a
>>>>> certain size (2880 X 2880), but when the matrix is set to be larger, the
>>>>> code crashes with a segfault and the error says it was in the
>>>>> MatAssemblyEnd().  Sometimes it works with -n 2, but typically it always
>>>>> crashes when using multi-core.
>>>>> Any ideas on what it could be?
>>>>> Thanks,
>>>>> Ron Caplan
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120730/3969f03e/attachment.html>
