[petsc-users] KSP no longer returning NaNs?
Jed Brown
jedbrown at mcs.anl.gov
Wed Jul 25 17:04:17 CDT 2012
On Wed, Jul 25, 2012 at 4:58 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> As always a COMPLETE error report is useful. There are a million ways
> you could see this change in behavior but we can't spend time guessing. At
> a minimum please send the entire error output.
> I note in 3.3 the KSPDefaultConverged() still checks for NAN and
> returns a negative converged reason (not an error) so I can only guess why
> you are getting different behavior without more information.,
This is probably the main complaint:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/7d6f5cbe67bc
> Barry
> On Jul 25, 2012, at 4:35 PM, Kirk, Benjamin (JSC-EG311) wrote:
> > Hello -
> > I've been using PETSc 3.1 for quite a while now and have been hesitant to
> > upgrade because of some new behavior I found in 3.2. Let me explain...
> > In petsc-3.1, if the KSP encountered a NaN it would return it to the
> > application code. We actually liked this feature because it gives us an
> > opportunity to catch the NaN and attempt recovery, in our case by
> decreasing
> > the time step and trying again.
> > It seems in petsc-3.2, however, that PETSc itself aborts internally, so
> we
> > are unable to recover from the situation.
> > Is there any way to get the old behavior back?
> > Thanks,
> > -Ben
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120725/a35b16d3/attachment.html>
