[petsc-users] PETSC_NULL_FUNCTION in petsc-3.2-p7/src/snes/examples/tests/ex14f.F
Adam Stanier adam.stanier-2 at postgrad.manchester.ac.uk
Tue Jul 24 09:35:12 CDT 2012
I got gcc and gfortran on the cluster updated to Red Hat 4.4.6-3. This solves the problem.
Many Thanks,
Adam
From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] on behalf of Adam Stanier [adam.stanier-2 at postgrad.manchester.ac.uk]
Sent: 24 July 2012 13:11
To: PETSc users list
Subject: Re: [petsc-users] PETSC_NULL_FUNCTION in petsc-3.2-p7/src/snes/examples/tests/ex14f.F
Satish,
Thanks for the quick reply, I had corrected that bug in 3.3 you mentioned before getting the linking bug. I have also tried the same configure line (and also a simple configure: ./configure --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich)  on another cluster and got the same problem. I think the problem may be related to gfortran version Red Hat 4.1.2 (there is 4.1.2-14 on one cluster and 4.1.2-46 on another cluster). Another petsc user found ex14f to compile fine with red hat 4.4.6 gfortran.
The only reference to PETSC_NULL_FUNCTION I can find is where it is declared with External PETSC_NULL_FUNCTION in petscsys.h. Is this set to zero somewhere, or is it just expected to return zero if it is not found?
Adam
Sent: 23 July 2012 18:03
To: petsc-users at mcs.anl.gov
Hello,
I am getting the following error message when linking a code:
../solver_3.2/libsel.a(p2_snes.o): In function `__p2_snes_mod__p2_snes_error':
/home/stanier/hifi/solver_3.2/p2_snes.F:450: undefined reference to `__local_mod__petsc_null_function'
collect2: ld returned 1 exit status
I have noticed that src/snes/examples/tests/ex14f.F also gives an error message related to PETSC_NULL_FUNCTION, and make ex14f fails to make
ex14f.o: In function `MAIN__':
/home/stanier/soft/petsc-3.2-p7/src/snes/examples/tests/ex14f.F:182: undefined reference to `__petscmod__petsc_null_function'
Also, have checked this with another PETSc user with version 3.2-p7 and version 3.3- the same error occurs.
My configure options are ./configure --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich --download-blacs --download-scalapack --download-parmetis --download-mumps --download-superlu --download-hypre
I was wondering if anyone else has had this problem, and knew how to get around it.
Adam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120724/494ec631/attachment.html>
