[petsc-users] Pthread support
Alexander Goncharov
alexvg77 at gmail.com
Mon Jul 23 22:00:54 CDT 2012
Hi Jed,
thank you for a quick reply. If I run ex2 with -mat_type seqaijpthread
-nthreads 4, everything runs fine. I see 400% utilization.
The problem persists if I just start two instances of the ex2 from the
console without seqaijpthread/seqpthread options. Just two single
processor jobs. They show up as two 50% jobs in the "top" output and run
slower. I hope I made my problem more clear.
Thank you,
Alexander.
On Mon, 2012-07-23 at 21:41 -0500, Jed Brown wrote:
> On Mon, Jul 23, 2012 at 9:08 PM, Alexander Goncharov
> <alexvg77 at gmail.com> wrote:
> Hello!
> I have a question about pthread support in PETSC. I could not
> find it in
> the development version. Is it going to be supported in the
> new release?
> The reason I tried development version is because in petsc-3.3
> compiled
> with pthreadclasses=1 all jobs would be sent to one core, if I
> start
> executables separately. Same for MPI, mpirun -np 4 would show
> up as 4
> processes with 25% CPU usage each, in the "top" output.
> Without
> pthreadclasses all is ok. I would have processes with each
> utilizing
> separate core at 100%. Have you come across such a behavior?
> Sounds like an affinity problem. When running with multiple MPI
> processes and threads, you generally have to specify the number of
> threads manually.
> The threading code is in the process of being overhauled to a cleaner
> and more flexible design. It's not ready for use yet, but should be in
> a couple months.
