[petsc-users] PETSC_NULL_FUNCTION in petsc-3.2-p7/src/snes/examples/tests/ex14f.F
Satish Balay
balay at mcs.anl.gov
Mon Jul 23 12:36:23 CDT 2012
On Mon, 23 Jul 2012, Adam Stanier wrote:
> Hello,
> I am getting the following error message when linking a code:
> ../solver_3.2/libsel.a(p2_snes.o): In function `__p2_snes_mod__p2_snes_error':
> /home/stanier/hifi/solver_3.2/p2_snes.F:450: undefined reference to `__local_mod__petsc_null_function'
> collect2: ld returned 1 exit status
> I have noticed that src/snes/examples/tests/ex14f.F also gives an error message related to PETSC_NULL_FUNCTION, and make ex14f fails to make
> ex14f.o: In function `MAIN__':
> /home/stanier/soft/petsc-3.2-p7/src/snes/examples/tests/ex14f.F:182: undefined reference to `__petscmod__petsc_null_function'
> Also, have checked this with another PETSc user with version 3.2-p7 and version 3.3- the same error occurs.
With petsc-3.3 - there is one compile error which the following patch
fixes. But i don't see the error you mention.
diff --git a/src/snes/examples/tests/ex14f.F b/src/snes/examples/tests/ex14f.F
--- a/src/snes/examples/tests/ex14f.F
+++ b/src/snes/examples/tests/ex14f.F
@@ -137,7 +137,7 @@
call VecDuplicate(x,U,ierr)
call PetscObjectSetName(U,'Exact Solution',ierr)
- call MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N, &
+ call MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N, &
& N,i3,PETSC_NULL_INTEGER,i0,PETSC_NULL_INTEGER,J,ierr)
call MatGetType(J,matrixname,ierr)
balay at petsc:/sandbox/balay/petsc33 $ ./configure --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich --download-blacs --download-scalapack --download-parmetis --download-mumps --download-superlu --download-hypre PETSC_ARCH=arch-test --download-metis
balay at petsc:/sandbox/balay/petsc33 $ make PETSC_DIR=/sandbox/balay/petsc33 PETSC_ARCH=arch-test all
Running test examples to verify correct installation
Using PETSC_DIR=/sandbox/balay/petsc33 and PETSC_ARCH=arch-test
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI processes
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
balay at petsc:/sandbox/balay/petsc33 $ cd src/snes/examples/tests/
balay at petsc:/sandbox/balay/petsc33/src/snes/examples/tests $ make ex14f
/sandbox/balay/petsc33/arch-test/bin/mpif90 -c -Wall -Wno-unused-variable -g -I/sandbox/balay/petsc33/include -I/sandbox/balay/petsc33/arch-test/include -o ex14f.o ex14f.F
/sandbox/balay/petsc33/arch-test/bin/mpif90 -Wall -Wno-unused-variable -g -o ex14f ex14f.o -L/sandbox/balay/petsc33/arch-test/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/sandbox/balay/petsc33/arch-test/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lblacs -lparmetis -lmetis -lHYPRE -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/x86_64-linux-gnu -lmpichcxx -lstdc++ -lsuperlu_4.3 -lflapack -lfblas -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
/bin/rm -f ex14f.o
balay at petsc:/sandbox/balay/petsc33/src/snes/examples/tests $ ./ex14f
Jacobian is built ...
Number of SNES iterations = 7
Satish
> My configure options are ./configure --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich --download-blacs --download-scalapack --download-parmetis --download-mumps --download-superlu --download-hypre
> I was wondering if anyone else has had this problem, and knew how to get around it.
> Thanks,
> Adam
