[petsc-users] How to investigate the reason for slow convergence	rate?
    Bao Kai
    paeanball at gmail.com
    Sun Jul 22 09:22:59 CDT 2012
Hi, Jed,
The following is the output.  Two equations are solved during each
time steps. One is using bicgstab is already very fast, the other one
is using gmres+ml.
The log_summary output can found in the end of the output.
Best Regards,
Kai
> Message: 6
> Date: Sun, 22 Jul 2012 07:16:07 -0500
> From: Jed Brown <jedbrown at mcs.anl.gov>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] How to investigate the reason for slow
> 	convergence rate?
> Message-ID:
> 	<CAM9tzSkxKz5FwFJJPZz0UO5eN-S45QsdQxmo7xnH345R1EdTEQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Please send -log_summary output with performance questions.
> On Sun, Jul 22, 2012 at 4:01 AM, Bao Kai <paeanball at gmail.com> wrote:
>> Hi, Matt,
>> I tried ML6.2 with petsc3.3 with default parameters by only specifying
>> the preconditioner to be PCML.  The KSP solver is gmres.
>> The convergence rate is much faster, while it still took much longer
>> time in total.
>> For example, for the problem with 500^3 mesh ( 125 million unknowns )
>> with 512nodes(4 processors per node) on bluegene/P , it tooks about
>> ten iterations to get convergent while the total time used is about
>> 400 seconds.
>>     506   the KSP type is gmres
>>     507   the PC type is ml
>>     508  KSP rtol =  0.100000000000000008E-04  abstol =
>> 0.100000000000000001E-49  dtol =  10000.0000000000000  maxit =  10000
>>     509  SNES rtol =  0.100000000000000002E-07  abstol =
>> 0.100000000000000001E-49  stol =  0.100000000000000002E-07  maxit =
>> 50  maxf=  10000
>>     510   0 SNES Function norm 5.859593121800e+02
>>     511     0 KSP Residual norm 8.340827070202e+06
>>     512     1 KSP Residual norm 7.980806572332e+05
>>     513     2 KSP Residual norm 1.870896731234e+05
>>     514     3 KSP Residual norm 6.790580947452e+04
>>     515     4 KSP Residual norm 2.665552335248e+04
>>     516     5 KSP Residual norm 1.130212349885e+04
>>     517     6 KSP Residual norm 4.053599972292e+03
>>     518     7 KSP Residual norm 1.786770710693e+03
>>     519     8 KSP Residual norm 7.313571654931e+02
>>     520     9 KSP Residual norm 3.205683714450e+02
>>     521    10 KSP Residual norm 1.263243312734e+02
>>     522    11 KSP Residual norm 3.945082815178e+01
>>     523   1 SNES Function norm 9.378772067642e-02
>>     524     0 KSP Residual norm 5.413489711800e+01
>>     525     1 KSP Residual norm 1.442598710609e+01
>>     526     2 KSP Residual norm 4.073537172140e+00
>>     527     3 KSP Residual norm 1.157455598705e+00
>>     528     4 KSP Residual norm 3.509855901968e-01
>>     529     5 KSP Residual norm 1.160625342728e-01
>>     530     6 KSP Residual norm 3.209351890216e-02
>>     531     7 KSP Residual norm 7.780869881329e-03
>>     532     8 KSP Residual norm 1.820828886636e-03
>>     533     9 KSP Residual norm 4.172544590190e-04
>>     534   2 SNES Function norm 6.747963806680e-07
>>     535  Number of KSP iteration is  9
>>     536  SNES solve takes time  406.724867261176314
>> But with bcgs and bjacobi, it tooks about 550 KSP iterations ( 2 snes
>> iterations ) and 69 seconds to get the result.
>> For much smaller problems, benefiting from the fast convergence, it
>> did takes less time to get the result. It seems that the ml can not be
>> scaled, or I used it in a wrong way.
>> Best Regards,
>> Kai
>> > Message: 2
>> > Date: Sat, 21 Jul 2012 08:47:10 -0500
>> > From: Matthew Knepley <knepley at gmail.com>
>> >       convergence rate?
>> > Message-ID:
>> CAMYG4GkfV6kmTFEKXUadOv+2CrKHk9hRY7UR-cFWf+vcRxCv5g at mail.gmail.com>
>> > Content-Type: text/plain; charset="iso-8859-1"
>> > On Sat, Jul 21, 2012 at 4:30 AM, Bao Kai <paeanball at gmail.com> wrote:
>> >>> HI, all,
>> >> I am still suffering from the slow convergence rate of the KSP
>> >> solution.
>> >> I changed the code to use Petsc3.3 and then try the gamg
>> >> precoditioner,
>> >> the convergence rate is better, while it took more total time because
>> >> it
>> >> took much more time for each iteration and some extra time for
>> >> pre-processing.
>> > Try ML to see if it has better defaults for your problem. If not, you
>> will
>> > have to start experimenting with the solver
>> > parameters.
>> >> I am wondering if there are some ways that can help me to investigate
>> the
>> >> slow convergence rate for KSP solution so that I can do some
>> improvement.
>> >>  Is DMMG will be a good solution?
>> > No.
>> >     Matt
>> >> Thank you very much.
>> >> Best Regards,
>> >> Kai
>> >>> Message: 2
>> >>> Date: Wed, 11 Jul 2012 15:17:15 -0500
>> >>> Subject: Re: [petsc-users] Does this mean the matrix is
>> >>>         ill-conditioned?
>> >>> Message-ID:
>> >>>         <CAMYG4Gk7T=
>> >>> q+w1PKO7G_TW07iDzux90Sncbv9K7d0FD-MDrLRg at mail.gmail.com>
>> >>> On Wed, Jul 11, 2012 at 12:40 PM, Bao Kai <paeanball at gmail.com>
>> >>> wrote:
>> >>> > Hi, all,
>> >>> > The following is the output from the solution of a Poisson equation
>> >>> > from Darcy's law.
>> >>> > To compute the condition number of matrix, I did not use PC and use
>> >>> > GMRES KSP to do the test.
>> >>> > It seems like that the condition number keep increasing during the
>> >>> > iterative solution. Does this mean the matrix is ill-conditioned?
>> >>> Generally yes. Krylov methods take a long time to resolve the
>> >>> smallest
>> >>> eigenvalues, so this approximation is not great.
>> >>> > For this test, it did not achieve convergence with 10000
>> >>> > iterations.
>> >>> > When I use BJOCABI PC and BICGSTAB KSP, it generally takes about
>> >>> > 600
>> >>> > times iteration to get the iteration convergent.
>> >>> > Any suggestion for improving the convergence rate will be much
>> >>> > appreciated.  The solution of this equation has been the bottleneck
>> of
>> >>> > my code, it takes more than 90% of the total time.
>> >>> Try ML or GAMG.
>> >>>     Matt
>> >>> > Best Regards,
>> >>> > Kai
>> > What most experimenters take for granted before they begin their
>> > experiments is infinitely more interesting than any results to which
>> their
>> > experiments lead.
>> > -- Norbert Wiener
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL:
>> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120721/eaf7b2ee/attachment-0001.html
> URL:
> <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120722/7f782dd6/attachment.html>
> petsc-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> End of petsc-users Digest, Vol 43, Issue 61
 RST runs on 2048 processors.
 Calculating the coloring takes time  76.9829076376470596
Start the simulation of RST_advection on a 3D rectanguluar mesh of size 500x500x500.
 call solve_CO2(conc) ...
 solve_CO2 starts iT =  1  (tCurr= 0.000000000000000000E+00 , tNext= 360.000000000000000 ) using backwardEuler
  the memory used initially in SolveNE_option is  780578816.000000000   in  0 th processor
 Calculating the Jacobian matrix using multi-coloring finite difference
 Calculating the Jacobian matrix using multi-coloring finite difference, end
 Calculating the Jacobian matrix takes time  0.362482352898041427E-04
  the KSP type is bcgs
  the PC type is bjacobi
 KSP rtol =  0.100000000000000008E-04  abstol =  0.100000000000000001E-49  dtol =  10000.0000000000000  maxit =  10000
 SNES rtol =  0.100000000000000002E-07  abstol =  0.100000000000000001E-49  stol =  0.100000000000000002E-07  maxit =  50  maxf=  10000
  0 SNES Function norm 2.027142332274e+05
    0 KSP Residual norm 1.329836410984e+05
    1 KSP Residual norm 2.003138625439e+02
    2 KSP Residual norm 1.080655908195e+00
  1 SNES Function norm 2.603715471664e+00
    0 KSP Residual norm 1.821752606793e+00
    1 KSP Residual norm 2.261877896690e-02
    2 KSP Residual norm 5.689587885989e-04
    3 KSP Residual norm 7.904719695607e-06
  2 SNES Function norm 1.303262560403e-05
 Number of KSP iteration is  3
 SNES solve takes time  6.39838860470588600
 Number of Newton iterations =  2
  the SNES Converged Reason is  3
  the memory used finally in SolveNE_option is  928034816.000000000   in  0 th processor
 solve_NE for concentration equations took time  6.40435670941175772
  the memory used initially in SolveNE_option is  928034816.000000000   in  0 th processor
 Calculating the Jacobian matrix takes time  0.465729411871507182E-04
  the PC type is ml
  0 SNES Function norm 6.854305936118e+02
    0 KSP Residual norm 8.373098135096e+06
    1 KSP Residual norm 7.298874883063e+05
    2 KSP Residual norm 1.312057861504e+05
    3 KSP Residual norm 2.940040817676e+04
    4 KSP Residual norm 5.550730454363e+03
    5 KSP Residual norm 9.403163430181e+02
    6 KSP Residual norm 1.989882957671e+02
    7 KSP Residual norm 3.776734457069e+01
  1 SNES Function norm 1.128845203882e-01
    0 KSP Residual norm 3.642500285026e+01
    1 KSP Residual norm 1.088628928189e+01
    2 KSP Residual norm 2.261263906033e+00
    3 KSP Residual norm 5.225048266035e-01
    4 KSP Residual norm 1.744244938506e-01
    5 KSP Residual norm 5.392736524647e-02
    6 KSP Residual norm 1.561840513585e-02
    7 KSP Residual norm 3.216915891215e-03
    8 KSP Residual norm 8.352256776033e-04
    9 KSP Residual norm 2.616795560745e-04
  2 SNES Function norm 4.222128984457e-07
 SNES solve takes time  396.688963249411700
  the memory used finally in SolveNE_option is  1108242432.00000000   in  0 th processor
 solve_NE for flow equations took time  396.693956828235287
 solve_CO2 starts iT =  2  (tCurr= 360.000000000000000 , tNext= 720.000000000000000 ) using backwardEuler
  the memory used initially in SolveNE_option is  1108242432.00000000   in  0 th processor
 Calculating the Jacobian matrix takes time  0.738905881689788657E-04
  0 SNES Function norm 1.744975811532e+07
    0 KSP Residual norm 6.042616216530e+06
    1 KSP Residual norm 2.411229464574e+06
    2 KSP Residual norm 9.384253591517e+05
    3 KSP Residual norm 8.172654250461e+05
    4 KSP Residual norm 3.278806775039e+05
    5 KSP Residual norm 1.892646740749e+05
    6 KSP Residual norm 1.688085534614e+05
    7 KSP Residual norm 1.070929112445e+05
    8 KSP Residual norm 8.894975127847e+04
    9 KSP Residual norm 8.439037109644e+04
   10 KSP Residual norm 2.210751081503e+05
   11 KSP Residual norm 8.018906048020e+05
   12 KSP Residual norm 2.463740463795e+05
   13 KSP Residual norm 4.701709773936e+05
   14 KSP Residual norm 2.572534693760e+05
   15 KSP Residual norm 1.400576861591e+06
   16 KSP Residual norm 6.843908357621e+04
   17 KSP Residual norm 6.835423406956e+04
   18 KSP Residual norm 3.306744876360e+05
   19 KSP Residual norm 1.274200720122e+05
   20 KSP Residual norm 2.864430197567e+05
   21 KSP Residual norm 6.303052018354e+04
   22 KSP Residual norm 1.040766852733e+04
   23 KSP Residual norm 1.403019031174e+04
   24 KSP Residual norm 8.304296941412e+03
   25 KSP Residual norm 5.063990038197e+03
   26 KSP Residual norm 2.072491899897e+04
   27 KSP Residual norm 2.833725405550e+04
   28 KSP Residual norm 6.025326846882e+02
   29 KSP Residual norm 2.012835940363e+02
   30 KSP Residual norm 9.871182569019e+01
   31 KSP Residual norm 7.994364942410e+01
   32 KSP Residual norm 8.722846666516e+01
   33 KSP Residual norm 3.278037987095e+01
  1 SNES Function norm 5.359315696689e+02
    0 KSP Residual norm 3.278037984348e+01
    1 KSP Residual norm 5.111266391765e+01
    2 KSP Residual norm 1.548643476480e+01
    3 KSP Residual norm 1.155495193877e+01
    4 KSP Residual norm 7.125481575618e+00
    5 KSP Residual norm 9.024848561174e+00
    6 KSP Residual norm 2.257573584187e+00
    7 KSP Residual norm 5.418784129233e-01
    8 KSP Residual norm 3.719657020252e-01
    9 KSP Residual norm 1.205608997222e-01
   10 KSP Residual norm 3.615255985887e+00
   11 KSP Residual norm 2.894677555372e-02
   12 KSP Residual norm 1.376453957581e-03
   13 KSP Residual norm 4.166968255993e-04
   14 KSP Residual norm 4.913433524474e-04
   15 KSP Residual norm 9.839518905020e-05
  2 SNES Function norm 2.253731138673e-03
 Number of KSP iteration is  15
 SNES solve takes time  11.2357833341176274
  the memory used finally in SolveNE_option is  1092841472.00000000   in  0 th processor
 solve_NE for concentration equations took time  11.2626100023528579
  the memory used initially in SolveNE_option is  1092841472.00000000   in  0 th processor
 Calculating the Jacobian matrix takes time  0.392435293861126411E-04
  the PC type is ml
  0 SNES Function norm 6.168715721071e+02
    0 KSP Residual norm 7.978767835480e+06
    1 KSP Residual norm 8.728618105505e+05
    2 KSP Residual norm 4.558368047941e+05
    3 KSP Residual norm 4.346984519871e+05
    4 KSP Residual norm 2.286709358986e+05
    5 KSP Residual norm 1.332498617875e+05
    6 KSP Residual norm 1.264578916032e+05
    7 KSP Residual norm 1.058066886132e+05
    8 KSP Residual norm 4.688543293468e+04
    9 KSP Residual norm 1.706033347392e+04
   10 KSP Residual norm 7.798848104292e+03
   11 KSP Residual norm 5.313346550965e+03
   12 KSP Residual norm 4.267989536057e+03
   13 KSP Residual norm 4.104126803381e+03
   14 KSP Residual norm 4.082103088618e+03
   15 KSP Residual norm 3.730866428917e+03
   16 KSP Residual norm 2.662009656165e+03
   17 KSP Residual norm 1.507688407744e+03
   18 KSP Residual norm 1.117001235096e+03
   19 KSP Residual norm 1.019680471256e+03
   20 KSP Residual norm 1.008960551221e+03
   21 KSP Residual norm 1.007162979788e+03
   22 KSP Residual norm 9.787062543248e+02
   23 KSP Residual norm 8.700126671308e+02
   24 KSP Residual norm 5.076825476614e+02
   25 KSP Residual norm 1.697222557097e+02
   26 KSP Residual norm 5.606185528901e+01
  1 SNES Function norm 1.303677605733e-01
    0 KSP Residual norm 1.275643534800e+02
    1 KSP Residual norm 1.755473787471e+01
    2 KSP Residual norm 4.019549783414e+00
    3 KSP Residual norm 7.944360565021e-01
    4 KSP Residual norm 1.499573425904e-01
    5 KSP Residual norm 2.452264940057e-02
    6 KSP Residual norm 5.066981841293e-03
    7 KSP Residual norm 9.904807389870e-04
  2 SNES Function norm 3.389130418502e-06
 Number of KSP iteration is  7
 SNES solve takes time  433.673481138823490
  the memory used finally in SolveNE_option is  1161392128.00000000   in  0 th processor
 solve_NE for flow equations took time  433.678236383529452
 solve_CO2 starts iT =  3  (tCurr= 720.000000000000000 , tNext= 1080.00000000000000 ) using backwardEuler
  the memory used initially in SolveNE_option is  1161392128.00000000   in  0 th processor
 Calculating the Jacobian matrix takes time  0.611341175726920483E-04
  0 SNES Function norm 1.746230911748e+07
    0 KSP Residual norm 6.056016610516e+06
    1 KSP Residual norm 2.410588606648e+06
    2 KSP Residual norm 9.456442885758e+05
    3 KSP Residual norm 8.094818865575e+05
    4 KSP Residual norm 3.287134485841e+05
    5 KSP Residual norm 1.896118306005e+05
    6 KSP Residual norm 1.754760017003e+05
    7 KSP Residual norm 1.074211675332e+05
    8 KSP Residual norm 8.892934191703e+04
    9 KSP Residual norm 8.425895560687e+04
   10 KSP Residual norm 2.210542597785e+05
   11 KSP Residual norm 7.832399341096e+05
   12 KSP Residual norm 2.473533515058e+05
   13 KSP Residual norm 4.614685234415e+05
   14 KSP Residual norm 2.551240693195e+05
   15 KSP Residual norm 1.373194764628e+06
   16 KSP Residual norm 6.869917844180e+04
   17 KSP Residual norm 6.827906464339e+04
   18 KSP Residual norm 3.315401022229e+05
   19 KSP Residual norm 1.282764833555e+05
   20 KSP Residual norm 2.897981334419e+05
   21 KSP Residual norm 6.308627435161e+04
   22 KSP Residual norm 1.045231001236e+04
   23 KSP Residual norm 1.491143524048e+04
   24 KSP Residual norm 8.656791195722e+03
   25 KSP Residual norm 5.045336356514e+03
   26 KSP Residual norm 2.166365912996e+04
   27 KSP Residual norm 3.094664062274e+04
   28 KSP Residual norm 6.117301214046e+02
   29 KSP Residual norm 2.012060974502e+02
   30 KSP Residual norm 9.900282227487e+01
   31 KSP Residual norm 8.011585552510e+01
   32 KSP Residual norm 8.686592920308e+01
   33 KSP Residual norm 3.278618019592e+01
  1 SNES Function norm 5.356912110054e+02
    0 KSP Residual norm 3.278618016861e+01
    1 KSP Residual norm 5.118173917522e+01
    2 KSP Residual norm 1.548726082616e+01
    3 KSP Residual norm 1.156812789566e+01
    4 KSP Residual norm 7.149486136715e+00
    5 KSP Residual norm 7.980447622207e+00
    6 KSP Residual norm 2.184234814452e+00
    7 KSP Residual norm 5.474499778219e-01
    8 KSP Residual norm 3.733409066648e-01
    9 KSP Residual norm 1.199274608307e-01
   10 KSP Residual norm 3.099768217390e-01
   11 KSP Residual norm 2.932626926870e-02
   12 KSP Residual norm 1.398491373209e-03
   13 KSP Residual norm 4.172815233796e-04
   14 KSP Residual norm 6.539192013676e-04
   15 KSP Residual norm 9.719451000433e-05
  2 SNES Function norm 2.224809336173e-03
 SNES solve takes time  11.2320685176470079
  the memory used finally in SolveNE_option is  1145991168.00000000   in  0 th processor
 solve_NE for concentration equations took time  11.2598186258823034
  the memory used initially in SolveNE_option is  1145991168.00000000   in  0 th processor
 Calculating the Jacobian matrix takes time  0.531258823457392282E-04
  the PC type is ml
  0 SNES Function norm 5.906457664566e+02
    0 KSP Residual norm 7.912814686693e+06
    1 KSP Residual norm 9.645782297768e+05
    2 KSP Residual norm 8.861064046254e+05
    3 KSP Residual norm 4.897630000578e+05
    4 KSP Residual norm 3.166880917820e+05
    5 KSP Residual norm 3.069992066317e+05
    6 KSP Residual norm 1.923010666939e+05
    7 KSP Residual norm 9.534057223926e+04
    8 KSP Residual norm 5.617225030104e+04
    9 KSP Residual norm 5.000967170570e+04
   10 KSP Residual norm 4.988510808219e+04
   11 KSP Residual norm 4.377142165464e+04
   12 KSP Residual norm 3.537339493753e+04
   13 KSP Residual norm 3.444119180522e+04
   14 KSP Residual norm 3.140632281962e+04
   15 KSP Residual norm 2.387794289515e+04
   16 KSP Residual norm 2.029305730532e+04
   17 KSP Residual norm 1.944823332521e+04
   18 KSP Residual norm 1.926082773332e+04
   19 KSP Residual norm 1.604520680206e+04
   20 KSP Residual norm 1.083092031672e+04
   21 KSP Residual norm 5.980890172430e+03
   22 KSP Residual norm 4.230302343358e+03
   23 KSP Residual norm 3.473716174483e+03
   24 KSP Residual norm 2.539150935402e+03
   25 KSP Residual norm 1.225826890173e+03
   26 KSP Residual norm 3.869466816538e+02
   27 KSP Residual norm 1.166013359601e+02
   28 KSP Residual norm 3.948921651246e+01
  1 SNES Function norm 9.374214140858e-02
    0 KSP Residual norm 4.314990451734e+01
    1 KSP Residual norm 3.515946386829e+01
    2 KSP Residual norm 2.695621438095e+01
    3 KSP Residual norm 1.390235007360e+01
    4 KSP Residual norm 1.386211256871e+01
    5 KSP Residual norm 7.834323161908e+00
    6 KSP Residual norm 5.517283406603e+00
    7 KSP Residual norm 5.426656354145e+00
    8 KSP Residual norm 3.458546275824e+00
    9 KSP Residual norm 2.340650733306e+00
   10 KSP Residual norm 2.308443591276e+00
   11 KSP Residual norm 1.978019536730e+00
   12 KSP Residual norm 1.751838848414e+00
   13 KSP Residual norm 1.748423642827e+00
   14 KSP Residual norm 1.558995531050e+00
   15 KSP Residual norm 1.434334333026e+00
   16 KSP Residual norm 1.429581841785e+00
   17 KSP Residual norm 1.234896777884e+00
   18 KSP Residual norm 1.113705072932e+00
   19 KSP Residual norm 1.113002183375e+00
   20 KSP Residual norm 1.000636547921e+00
   21 KSP Residual norm 7.666212672065e-01
   22 KSP Residual norm 4.954697001390e-01
   23 KSP Residual norm 3.763741385658e-01
   24 KSP Residual norm 3.061802852706e-01
   25 KSP Residual norm 2.172246927676e-01
   26 KSP Residual norm 1.263551553515e-01
   27 KSP Residual norm 8.065653452946e-02
   28 KSP Residual norm 6.666958151528e-02
   29 KSP Residual norm 5.969554338215e-02
   30 KSP Residual norm 4.701119423782e-02
   31 KSP Residual norm 3.880526060321e-02
   32 KSP Residual norm 3.550352775410e-02
   33 KSP Residual norm 3.518508431556e-02
   34 KSP Residual norm 3.365882337676e-02
   35 KSP Residual norm 2.990974854198e-02
   36 KSP Residual norm 2.960135454716e-02
   37 KSP Residual norm 2.642485998975e-02
   38 KSP Residual norm 2.207970762270e-02
   39 KSP Residual norm 2.207627751574e-02
   40 KSP Residual norm 1.939485668126e-02
   41 KSP Residual norm 1.826512902599e-02
   42 KSP Residual norm 1.776217373211e-02
   43 KSP Residual norm 1.494313801753e-02
   44 KSP Residual norm 1.491723533996e-02
   45 KSP Residual norm 1.294925018292e-02
   46 KSP Residual norm 1.031091165182e-02
   47 KSP Residual norm 9.274721439823e-03
   48 KSP Residual norm 9.199144088117e-03
   49 KSP Residual norm 7.380758295213e-03
   50 KSP Residual norm 5.312928096668e-03
   51 KSP Residual norm 3.590846812049e-03
   52 KSP Residual norm 3.453458627238e-03
   53 KSP Residual norm 2.682574287054e-03
   54 KSP Residual norm 1.535180831843e-03
   55 KSP Residual norm 1.124868394925e-03
   56 KSP Residual norm 9.042295611229e-04
   57 KSP Residual norm 6.864456305576e-04
   58 KSP Residual norm 4.500332684970e-04
   59 KSP Residual norm 2.315845183804e-04
  2 SNES Function norm 5.750728763041e-07
 Number of KSP iteration is  59
 SNES solve takes time  577.862047618823453
 solve_NE for flow equations took time  577.867189442352810
 solve_CO2 starts iT =  4  (tCurr= 1080.00000000000000 , tNext= 1440.00000000000000 ) using backwardEuler
 Calculating the Jacobian matrix takes time  0.689435294134455035E-04
  0 SNES Function norm 1.747595578968e+07
    0 KSP Residual norm 6.070738647764e+06
    1 KSP Residual norm 2.410071228327e+06
    2 KSP Residual norm 9.549253739214e+05
    3 KSP Residual norm 7.981187668861e+05
    4 KSP Residual norm 3.291532237393e+05
    5 KSP Residual norm 1.900364740271e+05
    6 KSP Residual norm 1.808298981550e+05
    7 KSP Residual norm 1.077099555482e+05
    8 KSP Residual norm 8.894381121663e+04
    9 KSP Residual norm 8.417853266785e+04
   10 KSP Residual norm 2.201981533464e+05
   11 KSP Residual norm 7.709268659791e+05
   12 KSP Residual norm 2.479014722435e+05
   13 KSP Residual norm 4.666147266566e+05
   14 KSP Residual norm 2.558241680066e+05
   15 KSP Residual norm 1.373629431710e+06
   16 KSP Residual norm 6.911910203172e+04
   17 KSP Residual norm 6.842401632722e+04
   18 KSP Residual norm 3.306049474142e+05
   19 KSP Residual norm 1.283124304691e+05
   20 KSP Residual norm 2.909356471676e+05
   21 KSP Residual norm 6.322781226246e+04
   22 KSP Residual norm 1.055406528283e+04
   23 KSP Residual norm 1.769757469826e+04
   24 KSP Residual norm 9.622138538562e+03
   25 KSP Residual norm 5.002105247328e+03
   26 KSP Residual norm 2.226851519086e+04
   27 KSP Residual norm 3.333932229927e+04
   28 KSP Residual norm 6.154801922084e+02
   29 KSP Residual norm 2.017271873264e+02
   30 KSP Residual norm 9.927125290556e+01
   31 KSP Residual norm 8.026861874655e+01
   32 KSP Residual norm 8.676016243921e+01
   33 KSP Residual norm 3.299156885807e+01
  1 SNES Function norm 5.386668000559e+02
    0 KSP Residual norm 3.299156885877e+01
    1 KSP Residual norm 5.156932987442e+01
    2 KSP Residual norm 1.559190093665e+01
    3 KSP Residual norm 1.166013674890e+01
    4 KSP Residual norm 7.234093208644e+00
    5 KSP Residual norm 7.150545499500e+00
    6 KSP Residual norm 2.129440698767e+00
    7 KSP Residual norm 5.576694756879e-01
    8 KSP Residual norm 3.788441553969e-01
    9 KSP Residual norm 1.193654283561e-01
   10 KSP Residual norm 1.595986614454e-01
   11 KSP Residual norm 2.993377362791e-02
   12 KSP Residual norm 1.432762216316e-03
   13 KSP Residual norm 4.171238217969e-04
   14 KSP Residual norm 9.270694825671e-04
   15 KSP Residual norm 9.451948560740e-05
  2 SNES Function norm 2.164055274017e-03
 SNES solve takes time  11.2357321717647665
 solve_NE for concentration equations took time  11.2634957200000372
 Calculating the Jacobian matrix takes time  0.580552941755740903E-04
  the PC type is ml
  0 SNES Function norm 5.637544127911e+02
    0 KSP Residual norm 8.074132757094e+06
    1 KSP Residual norm 8.162289267400e+05
    2 KSP Residual norm 2.485691052163e+05
    3 KSP Residual norm 1.694979473006e+05
    4 KSP Residual norm 1.692597553909e+05
    5 KSP Residual norm 1.141369714739e+05
    6 KSP Residual norm 5.411385565863e+04
    7 KSP Residual norm 2.907568800779e+04
    8 KSP Residual norm 2.195670663729e+04
    9 KSP Residual norm 1.987662933665e+04
   10 KSP Residual norm 1.984128544322e+04
   11 KSP Residual norm 1.896159506872e+04
   12 KSP Residual norm 1.529241417387e+04
   13 KSP Residual norm 1.159676508149e+04
   14 KSP Residual norm 8.386589100387e+03
   15 KSP Residual norm 6.545195108415e+03
   16 KSP Residual norm 4.670526409709e+03
   17 KSP Residual norm 2.616131111174e+03
   18 KSP Residual norm 1.340432005158e+03
   19 KSP Residual norm 6.930110261487e+02
   20 KSP Residual norm 3.501481900693e+02
   21 KSP Residual norm 1.624612621900e+02
   22 KSP Residual norm 8.693046524046e+01
   23 KSP Residual norm 6.266502671985e+01
  1 SNES Function norm 6.161796268733e-02
    0 KSP Residual norm 6.116148118636e+02
    1 KSP Residual norm 5.230020822749e+01
    2 KSP Residual norm 8.211943951986e+00
    3 KSP Residual norm 1.666142209341e+00
    4 KSP Residual norm 3.507550432364e-01
    5 KSP Residual norm 6.165808645033e-02
    6 KSP Residual norm 1.202676243967e-02
    7 KSP Residual norm 2.481833379192e-03
  2 SNES Function norm 8.769102970782e-06
    0 KSP Residual norm 2.228753345052e-03
    1 KSP Residual norm 7.086547861298e-04
    2 KSP Residual norm 2.208481325117e-04
    3 KSP Residual norm 1.451575632052e-04
    4 KSP Residual norm 1.418274746815e-04
    5 KSP Residual norm 9.951896679242e-05
    6 KSP Residual norm 6.710322416550e-05
    7 KSP Residual norm 4.951304989493e-05
    8 KSP Residual norm 4.517130650698e-05
    9 KSP Residual norm 4.516237226608e-05
   10 KSP Residual norm 4.204281863840e-05
   11 KSP Residual norm 3.107532296876e-05
   12 KSP Residual norm 2.213892288359e-05
   13 KSP Residual norm 1.311130661770e-05
   14 KSP Residual norm 7.469402767238e-06
   15 KSP Residual norm 4.676669974107e-06
   16 KSP Residual norm 3.240876159844e-06
   17 KSP Residual norm 3.034954224512e-06
   18 KSP Residual norm 3.032806716269e-06
   19 KSP Residual norm 2.969785088371e-06
   20 KSP Residual norm 2.538694624997e-06
   21 KSP Residual norm 1.879982074346e-06
   22 KSP Residual norm 1.255296471142e-06
   23 KSP Residual norm 7.489364422265e-07
   24 KSP Residual norm 5.322075248129e-07
   25 KSP Residual norm 4.222735297804e-07
   26 KSP Residual norm 3.111446552243e-07
   27 KSP Residual norm 1.943375346943e-07
   28 KSP Residual norm 1.065696516704e-07
   29 KSP Residual norm 5.044714108566e-08
   30 KSP Residual norm 2.083483747171e-08
  3 SNES Function norm 5.372515919004e-11
 Number of KSP iteration is  30
 SNES solve takes time  690.774282409411626
 Number of Newton iterations =  3
 solve_NE for flow equations took time  690.779385967058715
 solve_CO2 starts iT =  5  (tCurr= 1440.00000000000000 , tNext= 1800.00000000000000 ) using backwardEuler
 Calculating the Jacobian matrix takes time  0.581070585212728474E-04
  0 SNES Function norm 1.748870969739e+07
    0 KSP Residual norm 6.086246201886e+06
    1 KSP Residual norm 2.409389735394e+06
    2 KSP Residual norm 9.622200928047e+05
    3 KSP Residual norm 7.845100008720e+05
    4 KSP Residual norm 3.296569920221e+05
    5 KSP Residual norm 1.904589431018e+05
    6 KSP Residual norm 1.844373287795e+05
    7 KSP Residual norm 1.079285086282e+05
    8 KSP Residual norm 8.891984486588e+04
    9 KSP Residual norm 8.405179802744e+04
   10 KSP Residual norm 2.194780141626e+05
   11 KSP Residual norm 7.570843689971e+05
   12 KSP Residual norm 2.482349011189e+05
   13 KSP Residual norm 4.706092657967e+05
   14 KSP Residual norm 2.563244095318e+05
   15 KSP Residual norm 1.372950386269e+06
   16 KSP Residual norm 6.944283147672e+04
   17 KSP Residual norm 6.854632103265e+04
   18 KSP Residual norm 3.267800586436e+05
   19 KSP Residual norm 1.276852156441e+05
   20 KSP Residual norm 2.929806690176e+05
   21 KSP Residual norm 6.332255447748e+04
   22 KSP Residual norm 1.065666927107e+04
   23 KSP Residual norm 2.179427377587e+04
   24 KSP Residual norm 1.090989269498e+04
   25 KSP Residual norm 4.954750321830e+03
   26 KSP Residual norm 2.290314834484e+04
   27 KSP Residual norm 3.659049402840e+04
   28 KSP Residual norm 6.198874437352e+02
   29 KSP Residual norm 2.022064043710e+02
   30 KSP Residual norm 9.950110754634e+01
   31 KSP Residual norm 8.035889596931e+01
   32 KSP Residual norm 8.653039748403e+01
   33 KSP Residual norm 3.313695971119e+01
  1 SNES Function norm 5.407716079365e+02
    0 KSP Residual norm 3.313695972687e+01
    1 KSP Residual norm 5.184734109949e+01
    2 KSP Residual norm 1.566968138836e+01
    3 KSP Residual norm 1.172734056613e+01
    4 KSP Residual norm 7.295499990009e+00
    5 KSP Residual norm 6.644562948205e+00
    6 KSP Residual norm 2.090067616380e+00
    7 KSP Residual norm 5.650798874604e-01
    8 KSP Residual norm 3.828248875064e-01
    9 KSP Residual norm 1.188237451760e-01
   10 KSP Residual norm 1.219837906646e-01
   11 KSP Residual norm 3.044197530806e-02
   12 KSP Residual norm 1.437855652708e-03
   13 KSP Residual norm 4.252496839951e-04
   14 KSP Residual norm 1.998111152480e-04
  2 SNES Function norm 4.503925443016e-03
 Number of KSP iteration is  14
 SNES solve takes time  11.1125425270588494
 solve_NE for concentration equations took time  11.1403631105881686
 Calculating the Jacobian matrix takes time  0.470929412585974205E-04
  the PC type is ml
  0 SNES Function norm 5.419004356488e+02
    0 KSP Residual norm 8.261643592794e+06
    1 KSP Residual norm 7.386189854719e+05
    2 KSP Residual norm 1.584330883846e+05
    3 KSP Residual norm 3.364196291575e+04
    4 KSP Residual norm 7.368389136171e+03
    5 KSP Residual norm 1.543727655193e+03
    6 KSP Residual norm 3.911584281708e+02
    7 KSP Residual norm 7.263753586758e+01
  1 SNES Function norm 2.079911111668e-01
    0 KSP Residual norm 6.479513763967e+01
    1 KSP Residual norm 2.048884277583e+01
    2 KSP Residual norm 1.594847809383e+01
    3 KSP Residual norm 1.364588964425e+01
    4 KSP Residual norm 6.269501761207e+00
    5 KSP Residual norm 4.035896337551e+00
    6 KSP Residual norm 4.031872117187e+00
    7 KSP Residual norm 2.768850078744e+00
    8 KSP Residual norm 1.403725412629e+00
    9 KSP Residual norm 7.626536014837e-01
   10 KSP Residual norm 6.202328834215e-01
   11 KSP Residual norm 5.350435338368e-01
   12 KSP Residual norm 4.666283999150e-01
   13 KSP Residual norm 3.994738205585e-01
   14 KSP Residual norm 2.771523168855e-01
   15 KSP Residual norm 2.055070828125e-01
   16 KSP Residual norm 1.791698744783e-01
   17 KSP Residual norm 1.461949045869e-01
   18 KSP Residual norm 9.828913420095e-02
   19 KSP Residual norm 5.776184245190e-02
   20 KSP Residual norm 3.376848313794e-02
   21 KSP Residual norm 2.191994279649e-02
   22 KSP Residual norm 1.907722095018e-02
   23 KSP Residual norm 1.857170395786e-02
   24 KSP Residual norm 1.828402291612e-02
   25 KSP Residual norm 1.788622756769e-02
   26 KSP Residual norm 1.688091022039e-02
   27 KSP Residual norm 1.340769361306e-02
   28 KSP Residual norm 7.135059196478e-03
   29 KSP Residual norm 2.447119579046e-03
   30 KSP Residual norm 7.151815788560e-04
   31 KSP Residual norm 2.848411909092e-04
  2 SNES Function norm 8.677875468083e-07
 Number of KSP iteration is  31
 SNES solve takes time  447.630811501176595
 solve_NE for flow equations took time  447.635830009412075
 The simulation takes time (no initialization and finalization)  2598.08699473647039
 The time for the flow equation solving (SNES) is  2546.65459863058823
 The time for the concentration equation solving (SNES) is  51.3306441682352670
 The total time for SNES is  2597.98524279882349
 solve_CO2(conc) done.
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./rst on a arch-shah named ionode65 with 2048 processors, by Unknown Sun Jul 22 16:50:55 2012
Using Petsc Release Version 3.3.0, Patch 2, Fri Jul 13 15:42:00 CDT 2012
                         Max       Max/Min        Avg      Total
Time (sec):           2.675e+03      1.00001   2.675e+03
Objects:              4.818e+03      1.00000   4.818e+03
Flops:                1.466e+10      1.11589   1.377e+10  2.820e+13
Flops/sec:            5.478e+06      1.11589   5.148e+06  1.054e+10
MPI Messages:         2.549e+06     18.36763   1.762e+06  3.609e+09
MPI Message Lengths:  3.313e+08      2.11656   1.667e+02  6.017e+11
MPI Reductions:       5.812e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 2.6754e+03 100.0%  2.8204e+13 100.0%  3.609e+09 100.0%  1.667e+02      100.0%  5.811e+03 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
PetscBarrier          10 1.0 1.1748e-0211.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESSolve             10 1.0 2.5979e+03 1.0 1.47e+10 1.1 3.6e+09 1.7e+02 5.7e+03 97100100100 98  97100100100 98 10857
SNESFunctionEval      31 1.0 9.2333e-01 1.2 0.00e+00 0.0 1.4e+06 3.5e+03 2.0e+00  0  0  0  1  0   0  0  0  1  0     0
SNESJacobianEval      21 1.0 5.0506e+01 1.0 7.33e+07 1.1 2.7e+07 3.5e+03 4.5e+01  2  1  1 16  1   2  1  1 16  1  2812
SNESLineSearch        21 1.0 1.2610e+00 1.0 8.81e+07 1.1 1.9e+06 3.5e+03 8.4e+01  0  1  0  1  1   0  1  0  1  1 134858
VecDot               413 1.0 1.4155e+00 4.7 5.33e+07 1.1 0.0e+00 0.0e+00 4.1e+02  0  0  0  0  7   0  0  0  0  7 72941
VecDotNorm2          196 1.0 1.1593e+00 9.0 5.06e+07 1.1 0.0e+00 0.0e+00 2.0e+02  0  0  0  0  3   0  0  0  0  3 84533
VecMDot              234 1.0 3.7595e+00 2.4 3.90e+08 1.1 0.0e+00 0.0e+00 2.3e+02  0  3  0  0  4   0  3  0  0  4 200889
VecNorm              496 1.0 1.1166e+00 2.5 6.40e+07 1.1 0.0e+00 0.0e+00 5.0e+02  0  0  0  0  9   0  0  0  0  9 111056
VecScale            4693 1.0 2.9463e-01 1.4 3.52e+07 1.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 224870
VecCopy              642 1.0 2.3825e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              2769 1.0 1.2421e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             2064 1.0 7.9276e-01 1.4 1.15e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 280230
VecAYPX             1482 1.0 4.0547e-01 1.2 1.98e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 94524
VecAXPBYCZ           392 1.0 7.8397e-01 1.3 1.01e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 250009
VecWAXPY             413 1.0 2.6542e-01 1.3 5.19e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 379120
VecMAXPY             247 1.0 1.4193e+00 1.2 4.20e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 573348
VecScatterBegin     7853 1.0 4.9287e+0127.9 0.00e+00 0.0 3.4e+09 1.8e+02 0.0e+00  0  0 94100  0   0  0 94100  0     0
VecScatterEnd       7853 1.0 4.1848e+02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  13  0  0  0  0     0
VecReduceArith        52 1.0 2.3512e-02 1.1 6.71e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 552907
VecReduceComm         31 1.0 9.8284e-02 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 3.1e+01  0  0  0  0  1   0  0  0  0  1     0
VecNormalize         247 1.0 6.7727e-01 1.8 4.78e+07 1.1 0.0e+00 0.0e+00 2.5e+02  0  0  0  0  4   0  0  0  0  4 136762
MatMult             3723 1.0 1.7651e+02 5.4 3.85e+09 1.1 8.6e+08 2.3e+02 0.0e+00  5 26 24 32  0   5 26 24 32  0 42048
MatMultAdd          1482 1.0 2.3328e+0211.6 3.97e+07 1.1 0.0e+00 0.0e+00 2.2e+01  3  0  0  0  0   3  0  0  0  0   329
MatSolve             649 1.0 1.0815e+01 1.1 1.30e+09 1.1 0.0e+00 0.0e+00 0.0e+00  0  9  0  0  0   0  9  0  0  0 233096
MatSOR              2964 1.0 3.9407e+02 3.9 8.07e+09 1.1 2.5e+09 1.1e+02 9.9e+02 11 55 69 47 17  11 55 69 47 17 39298
MatLUFactorSym        11 1.0 1.1463e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.3e+01  0  0  0  0  1   0  0  0  0  1     0
MatLUFactorNum        21 1.0 2.4922e+00 1.1 1.45e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 112406
MatILUFactorSym        5 1.0 2.2485e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin     110 1.0 2.6155e+00 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+02  0  0  0  0  3   0  0  0  0  3     0
MatAssemblyEnd       110 1.0 4.2814e+00 2.7 0.00e+00 0.0 7.1e+07 2.1e+01 5.4e+02  0  0  2  0  9   0  0  2  0  9     0
MatGetRowIJ           16 1.0 1.3113e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering        16 1.0 1.4726e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.2e+01  0  0  0  0  1   0  0  0  0  1     0
MatZeroEntries        21 1.0 1.0455e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatFDColorCreate       1 1.0 7.6147e+01 1.0 0.00e+00 0.0 8.9e+04 8.7e+02 9.2e+01  3  0  0  0  2   3  0  0  0  2     0
MatFDColorApply       21 1.0 5.0506e+01 1.0 7.33e+07 1.1 2.7e+07 3.5e+03 4.5e+01  2  1  1 16  1   2  1  1 16  1  2812
MatFDColorFunc       588 1.0 1.8813e+01 1.2 0.00e+00 0.0 2.6e+07 3.5e+03 0.0e+00  1  0  1 15  0   1  0  1 15  0     0
MatGetRedundant       11 1.0 1.0325e+01 1.3 0.00e+00 0.0 1.4e+08 6.0e+00 4.4e+01  0  0  4  0  1   0  0  4  0  1     0
KSPGMRESOrthog       234 1.0 4.9073e+00 1.7 7.80e+08 1.1 0.0e+00 0.0e+00 2.3e+02  0  5  0  0  4   0  5  0  0  4 307807
KSPSetUp             119 1.0 8.7377e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+02  0  0  0  0  4   0  0  0  0  4     0
KSPSolve              21 1.0 2.5458e+03 1.0 1.45e+10 1.1 3.6e+09 1.4e+02 5.5e+03 95 99 99 83 95  95 99 99 83 95 10955
PCSetUp               31 1.0 1.9466e+03 1.0 5.28e+08 1.1 2.2e+08 1.1e+02 2.9e+03 73  4  6  4 50  73  4  6  4 50   524
PCSetUpOnBlocks       10 1.0 2.7321e+00 1.1 1.45e+08 1.1 0.0e+00 0.0e+00 1.5e+01  0  1  0  0  0   0  1  0  0  0 102534
PCApply              649 1.0 5.8003e+02 1.0 1.06e+10 1.1 3.3e+09 1.1e+02 1.0e+03 22 72 92 63 17  22 72 92 63 17 35241
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container    13             13         4212     0
                SNES     1              1          812     0
      SNESLineSearch     1              1          536     0
              Vector  3975           3975    476579708     0
      Vector Scatter    92             92        58512     0
              Matrix   371            371    223370840     0
  Matrix FD Coloring     1              1     13832832     0
    Distributed Mesh     3              3       608136     0
     Bipartite Graph     6              6         2424     0
           Index Set   260            260      2533560     0
   IS L to G Mapping     2              2       301224     0
              Viewer     1              0            0     0
       Krylov Solver    46             46       118572     0
      Preconditioner    46             46        27124     0
Average time to get PetscTime(): 3.50475e-06
Average time for MPI_Barrier(): 3.76701e-06
Average time for zero size MPI_Send(): 1.35483e-05
#PETSc Option Table entries:
-ksp_monitor
-log_summary
-snes_monitor
#End of PETSc Option Table entries
Compiled with FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Sat Jul 21 18:38:13 2012
Configure options: --known-bits-per-byte=8 --known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768 --known-memcmp-ok --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=4 --known-sizeof-short=2 --known-sizeof-size_t=4 --known-sizeof-void-p=4 --with-batch=1 --download-f-blas-lapack=1 --with-cc=mpixlc_r --with-cxx=mpixlcxx_r --with-debugging=0 --with-fc="mpixlf77_r -qnosave" --with-fortran-kernels=1 --with-is-color-value-type=short --with-shared-libraries=0 --with-x=0 -COPTFLAGS="-O3 -qarch=450d -qtune=450 -qmaxmem=-1" -CXXOPTFLAGS="-O3 -qarch=450d -qtune=450 -qmaxmem=-1" -FOPTFLAGS="-O3 -qarch=450d -qtune=450 -qmaxmem=-1" --download-ml=1 PETSC_ARCH=arch-shaheen-bgp-opt
Libraries compiled on Sat Jul 21 18:38:13 2012 on fen1
Machine characteristics: Linux-2.6.16.60-0.93.1-ppc64-ppc64-with-SuSE-10-ppc
Using PETSc directory: /home/kaibao/petsc-3.3-p2
Using PETSc arch: arch-shaheen-bgp-opt
Using C compiler: mpixlc_r  -O3 -qarch=450d -qtune=450 -qmaxmem=-1  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpixlf77_r -qnosave  -O3 -qarch=450d -qtune=450 -qmaxmem=-1   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/include -I/home/kaibao/petsc-3.3-p2/include -I/home/kaibao/petsc-3.3-p2/include -I/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/include -I/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/default/include -I/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/sys/include
Using C linker: mpixlc_r
Using Fortran linker: mpixlf77_r -qnosave
Using libraries: -Wl,-rpath,/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/lib -L/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/lib -lpetsc -lpthread -Wl,-rpath,/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/lib -L/home/kaibao/petsc-3.3-p2/arch-shaheen-bgp-opt/lib -lml -L/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/default/lib -L/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/sys/lib -L/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/runtime/SPI -L/opt/ibmcmp/xlsmp/bg/1.7/bglib -L/opt/ibmcmp/xlmass/bg/4.4/bglib -L/opt/ibmcmp/vac/bg/9.0/bglib -L/opt/ibmcmp/vacpp/bg/9.0/bglib -L/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc-bgp-linux/4.1.2 -L/bgsys/drivers/ppcfloor/gnu-linux/powerpc-bgp-linux/lib -Wl,-rpath,/opt/ibmcmp/lib/bg/bglib -Wl,-rpath,/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/default/lib -Wl,-rpath,/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/comm/sys/lib -Wl,-rpath,/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/runtime/SPI -lcxxmpich.cnk -libmc++ -lstdc++ -lflapack -lfblas -L/opt/ibmcmp/xlf/bg/11.1/bglib -lxlf90_r -lxlomp_ser -lxlfmath -lm -lcxxmpich.cnk -libmc++ -lstdc++ -lcxxmpich.cnk -libmc++ -lstdc++ -ldl -lmpich.cnk -lopa -ldcmf.cnk -ldcmfcoll.cnk -lpthread -lSPI.cna -lrt -lxlopt -lxl -lgcc_eh -ldl
 Finish RST_CO2.
 Finish interpreting the file infile_RSTi.m by RST.
 after mpi_finalize: ierr =  0
