[petsc-users] How to use petsc in a dynamically loaded	shared	library?
    Florian Beck
    Flo.44 at gmx.de
    Fri Jul 20 01:39:15 CDT 2012
On Thu, Jul 19, 2012 at 2:40 AM, Florian Beck <Flo.44 at gmx.de> wrote:
>> In the debugger is the adress of my vector at the beginning and the end
>> the same, but if I look inside the vector the adress of ops, map and >data
>> are 0x0 after I call the function VecDuplicate(). Is there a function to
>> synchronize the vectors before I destroy them?
>Sounds like a reference-counting bug. The most common cause is basically
>Vec X,Y;
>VecCreate(comm,&X);
>Y = X;
>VecDestroy(&X);
>VecDestroy(&Y);
>(perhaps spread across multiple functions, and perhaps with a reference
>obtained through a function that does not give you an "ownership share" by
>incrementing reference count).
>You can use "watch -l X->hdr.refct" in recent gdb to follow all the
>locations where reference count was changed (this includes the library), >if
>you need a heavyweight methodology for tracking down the error.
I have looked for the counting bug, but I haven't found anything because my gdb crashes.
Is it not possible to restore the addresses ops, map and data? I think it's possible to get values and from the vectors, so why shouldn't it possible to destroy them? Or is it possible to destroy the Vectors manually?
