[petsc-users] MatRARt
John Fettig
john.fettig at gmail.com
Wed Jul 18 15:18:51 CDT 2012
Hong,
That is what was pasted into the email. For good measure, I have
attached it to this email (I also modified it to compute RARt using
MatMatTransposeMult and MatMatMult).
John
On Wed, Jul 18, 2012 at 4:13 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Can I have your rart_simple.c for debugging?
> Hong
> On Wed, Jul 18, 2012 at 12:09 PM, John Fettig <john.fettig at gmail.com> wrote:
>> Should MatRARt work for SeqAIJ matrices? I don't understand what is
>> wrong with this test code:
>> #include <petsc.h>
>> #undef __FUNCT__
>> #define __FUNCT__ "main"
>> int main(int argc,char **args)
>> Mat A,R,C;
>> PetscInt ai[5] = {0,2,4,6,8};
>> PetscInt aj[8] = {0,3,1,2,1,2,0,3};
>> PetscReal av[8] = {1,2,3,4,5,6,7,8};
>> PetscInt ri[3] = {0,1,2};
>> PetscInt rj[2] = {1,2};
>> PetscReal rv[2] = {1,1};
>> PetscErrorCode ierr;
>> PetscInitialize(&argc,&args,(char *)0,(char *)0);
>> ierr =
>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,4,4,ai,aj,av,&A);CHKERRQ(ierr);
>> ierr =
>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,2,4,ri,rj,rv,&R);CHKERRQ(ierr);
>> //this is ok:
>> //ierr = MatMatMult(R,A,MAT_INITIAL_MATRIX,1.0,&C);CHKERRQ(ierr);
>> //this is not:
>> ierr = MatRARt(A,R,MAT_INITIAL_MATRIX,1.0,&C);CHKERRQ(ierr);
>> ierr = PetscFinalize();
>> return 0;
>> When I run it, it says:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: No support for this operation for this object type!
>> [0]PETSC ERROR: MatGetColumnIJ() not supported for matrix type seqaij!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13
>> 15:42:00 CDT 2012
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./rart_simple on a linux-deb named lagrange.tomato by
>> jfe Wed Jul 18 13:07:33 2012
>> [0]PETSC ERROR: Libraries linked from
>> /home/jfe/local/petsc-3.3-p2/linux-debug/lib
>> [0]PETSC ERROR: Configure run at Wed Jul 18 13:00:59 2012
>> [0]PETSC ERROR: Configure options --with-x=0
>> --download-f-blas-lapack=1 --with-mpi=1 --with-mpi-shared=1
>> --with-mpi=1 --download-mpich=1 --with-debugging=1
>> --with-gnu-compilers=yes --with-shared-libraries=1 --with-c++-support
>> --with-clanguage=C
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatTransposeColoringCreate_SeqAIJ() line 1294 in
>> /home/jfe/local/petsc-3.3-p2/src/mat/impls/aij/seq/matmatmult.c
>> [0]PETSC ERROR: MatTransposeColoringCreate() line 9318 in
>> /home/jfe/local/petsc-3.3-p2/src/mat/interface/matrix.c
>> [0]PETSC ERROR: MatRARtSymbolic_SeqAIJ_SeqAIJ() line 342 in
>> /home/jfe/local/petsc-3.3-p2/src/mat/impls/aij/seq/matrart.c
>> [0]PETSC ERROR: MatRARt_SeqAIJ_SeqAIJ() line 541 in
>> [0]PETSC ERROR: MatRARt() line 8405 in
>> [0]PETSC ERROR: main() line 25 in
>> src/ksp/ksp/examples/tutorials/rart_simple.c
>> What am I doing wrong?
>> Thanks,
>> John
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120718/3b26383d/attachment.c>
