[petsc-users] How to use petsc in a dynamically loaded shared library?
Jed Brown
jedbrown at mcs.anl.gov
Wed Jul 18 09:15:21 CDT 2012
On Wed, Jul 18, 2012 at 8:52 AM, Florian Beck <Flo.44 at gmx.de> wrote:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 3, Fri Jun 4 15:34:52
> CDT 2010
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: -no_signal_handler,--with-dynamic-loading on a linux-gnu
> named riemann by beck Wed Jul 18 15:41:20 2012
> [0]PETSC ERROR: Libraries linked from
> /home/hazelsct/repositories/petsc/linux-gnu-c-opt/lib
> [0]PETSC ERROR: Configure run at Wed Aug 4 15:00:14 2010
> [0]PETSC ERROR: Configure options --with-shared --with-debugging=0
> --useThreads 0 --with-clanguage=C++ --with-c-support
> --with-fortran-interfaces=1 --with-mpi-dir=/usr/lib/openmpi
> --with-mpi-shared=1 --with-blas-lib=-lblas --with-lapack-lib=-llapack
> --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse
> --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"
> --with-spooles=1 --with-spooles-include=/usr/include/spooles
> --with-spooles-lib=/usr/lib/libspooles.so --with-hypre=1
> --with-hypre-dir=/usr --with-scotch=1
> --with-scotch-include=/usr/include/scotch
> --with-scotch-lib=/usr/lib/libscotch.so --with-hdf5=1 --with-hdf5-dir=/usr
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
This is in your code. Run in a debugger to find out what's wrong.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> > > Of course I have a memory leak, because I'm not using the functions to
> > > destroy my vectors. Is there a simple example how to use the
> > petsc-library
> > > in a program like the following pseudo-code:
> > Is MPI initialized before this is called? Did you plan to do this in
> > parallel? Are you linking PETSc dynamically (as in, you dlopen and dlsym
> > PETSc functions to call them, or perhaps you declare weak symbols in your
> > code), linking your app-specific solver module (you call PETSc normally
> > and
> > use dlsym at a higher level), or something else? Remember to configure
> > PETSc --with-dynamic-loading if necessary.
> I plan to use it parallel, but first I want to calculate serial. I'm using
> dlopen to link my library.
> What happens if I call the PetsInitalize function several times? I call it
> in every function call.
You can call it multiple times, but MPI_Init() can only be called once. We
usually recommend that people only call PetscInitialize once (the
logging/profiling/debugging infrastructure is more useful that way).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120718/bf264fcc/attachment.html>
