[petsc-users] block size
Hong Zhang
hzhang at mcs.anl.gov
Wed Jul 18 09:10:20 CDT 2012
You use same datafile 'vec.dat' for writing two different vectors,
V3 and V1:
ierr = VecView(V1, view_out);
ierr = VecView(V3, view_out);
// here, vec.dat holds V3
Then read it in the order
ierr = VecLoad(V1, view_in);
//crash here because reading V3 into V1
ierr = VecLoad(V3, view_in);
Comment out one of vectors, your code works fine.
Hong
On Wed, Jul 18, 2012 at 7:54 AM, Anton Popov <popov at uni-mainz.de> wrote:
> Dear petsc team,
> could you please tell me what's wrong with the attached example file?
> I run it on 4 processors with petsc-3.3-p1.
> What could error message "Local size 1000 not compatible with block size
> 3!" mean?
> I've another question related to this issue. What is the real purpose of
> PetscViewerBinarySkipInfo function?
> I see no reason to skip creating "info" file, because the file produced by
> the attached example seems to be correct.
> Moreover, similar block size error occurs in our code while reading file
> with multiple vectors, irrespective whether "info" file exists or not.
> Thank you,
> Anton
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120718/639d73fe/attachment-0001.html>
