[petsc-users] ubuntu default mpich gives error with parmetis
Alexander Grayver
agrayver at gfz-potsdam.de
Wed Jul 18 04:56:51 CDT 2012
Sorry, it was my fault. This error happened because I first tried to
build PETSc with --download-mpich and then used same directory bu
without this options thus previously downloaded and configured MPICH
library was actually used although I implied PETSc to use ubuntu's MPICH.
On 18.07.2012 11:49, Alexander Grayver wrote:
> Hello PETSc team,
> Trying to configure petsc on ubuntu with installed mpich (apt-get
> install mpich2) like that:
> ./configure --with-petsc-arch=mpich-gcc-double-debug-f
> --with-fortran-interfaces=1 --download-mumps --download-metis
> --download-scalapack --download-blacs --with-scalar-type=real
> --download-blas-lapack --with-precision=double --download-parmetis
> --with-shared-libraries=1
> Give me following error:
> /usr/bin/ld:
> /home/lib/petsc-3.3-p2/mpich-gcc-double-debug-f/lib/libmpich.a(allreduce.o):
> relocation R_X86_64_32S against `MPID_Op_builtin' can not be used when
> making a shared object; recompile with -fPIC
> /home/lib/petsc-3.3-p2/mpich-gcc-double-debug-f/lib/libmpich.a: could
> not read symbols: Bad value
> collect2: ld returned 1 exit status
> make[2]: *** [libparmetis/libparmetis.so] Error 1
> make[1]: *** [libparmetis/CMakeFiles/parmetis.dir/all] Error 2
> make: *** [all] Error 2
> I'm not sure what should I recompile with -fPIC and would it help at all?
> This doesn't happen when using --download-mpich though.
> Thanks.
Alexander
