[petsc-users] Parallel Incomplete Choleski Factorization
Michele Rosso
mrosso at uci.edu
Tue Jul 17 17:28:17 CDT 2012
Thank a lot.
Please let me know when version 3.3 is available.
Michele
On 07/17/2012 12:13 PM, Barry Smith wrote:
>>> Please update to petsc-3.3. petsc-3.1 is too old.
>> I would do that but the version installed on the platform (Intrepid at ALCF) I am working on is 3.1-p2.
> Satish,
> Please fix this.
> Thanks
> Barry
> On Jul 17, 2012, at 1:36 PM, Michele Rosso wrote:
>> On 07/17/2012 11:03 AM, Hong Zhang wrote:
>>> Michele :
>>> I have some problems with the block jacobi preconditioner.
>>> I am solving a 3D Poisson equation with periodic BCs, discretized by using finite differences (7-points stencil).
>>> Thus the problem is singular and the nullspace has to be removed.
>>> For Poisson equations, multigrid precondition should be the method of
>>> choice.
>> Thank you for the suggestion. I do not have any experience with multigrid, but I will try.
>>> If I solve with the PCG method + JACOBI preconditioner the results are fine.
>>> If I use PCG + Block Jacobi preconditioner + ICC on each block the results are fine on the majority of the processors,
>>> but on few of them the error is very large.
>>> How do you know " few of them"?
>> Basically the solution is not correct on some grid points, say 6 grid nodes out of 64^3. The 6 grid nodes with problems belongs to 2 of the 128 processors
>> I am using.
>>> Do you have any idea/suggestions on how to fix this problem?
>>> This is the fragment of code I am using ( petsc 3.1 and Fortran 90):
>>> PetscErrorCode petsc_err
>>> Mat A
>>> PC pc, subpc
>>> KSP ksp
>>> KSP subksp(1)
>>> call KSPCreate(PETSC_COMM_WORLD,ksp,petsc_err)
>>> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,petsc_err)
>>> call KSPSetType(ksp,KSPCG, ) !the default type is gmres. I guess you want CG
>>> call KSPGetPC(ksp,pc,petsc_err)
>>> call PCSetType(pc,PCBJACOBI,petsc_err)
>>> ! call KSPSetUp(ksp,petsc_err) call this at the end
>>> ! KSP context for each single block
>>> call PCBJacobiGetSubKSP(pc,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,subksp(1),petsc_err)
>>> call KSPGetPC(subksp(1),subpc,petsc_err)
>>> call PCSetType(subpc,PCICC,petsc_err)
>>> call KSPSetType(subksp(1),KSPPREONLY petsc_err)
>>> call KSPSetTolerances(subksp(1),tol ,PETSC_DEFAULT_DOUBLE_PRECISION,&
>>> & PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,petsc_err)
>>> ! Remove nullspace from the singular system (Check PETSC_NULL)
>>> call MatNullSpaceCreate(MPI_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL,nullspace,petsc_err)
>>> call KSPSetNullSpace(ksp, nullspace, petsc_err)
>>> call MatNullSpaceRemove(nullspace, b, PETSC_NULL,petsc_err)
>>> call KSPSolve(ksp,b,x,petsc_err)
>>> I modified your code slightly. All these options can be provided at runtime:
>>> '-ksp_type cg -pc_type bjacobi -sub_pc_type icc'
>>> Hong
>>> On 07/13/2012 12:14 PM, Hong Zhang wrote:
>>>> Michele :
>>>> I need to use the ICC factorization as preconditioner, but I noticed that no parallel version is supported.
>>>> Is that correct?
>>>> Correct.
>>>> If so, is there a work around, like building the preconditioner "by hand" by using PETSc functions?
>>>> You may try block jacobi with icc in the blocks '-ksp_type cg -pc_type bjacobi -sub_pc_type icc'
>>>> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120717/31b6707d/attachment.html>
