[petsc-users] Parallel Incomplete Choleski Factorization
Hong Zhang
hzhang at mcs.anl.gov
Tue Jul 17 13:03:32 CDT 2012
Michele :
> I have some problems with the block jacobi preconditioner.
> I am solving a 3D Poisson equation with periodic BCs, discretized by
> using finite differences (7-points stencil).
> Thus the problem is singular and the nullspace has to be removed.
For Poisson equations, multigrid precondition should be the method of
choice.
If I solve with the PCG method + JACOBI preconditioner the results are fine.
> If I use PCG + Block Jacobi preconditioner + ICC on each block the results
> are fine on the majority of the processors,
> but on few of them the error is very large.
How do you know " few of them"?
Do you have any idea/suggestions on how to fix this problem?
> This is the fragment of code I am using ( petsc 3.1 and Fortran 90):
Please update to petsc-3.3. petsc-3.1 is too old.
> PetscErrorCode petsc_err
> Mat A
> PC pc, subpc
> KSP ksp
> KSP subksp(1)
> call KSPCreate(PETSC_COMM_WORLD,ksp,petsc_err)
> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,petsc_err)
call KSPSetType(ksp,KSPCG, ) !the default type is gmres. I guess you want CG
call KSPGetPC(ksp,pc,petsc_err)
> call PCSetType(pc,PCBJACOBI,petsc_err)
> ! call KSPSetUp(ksp,petsc_err) call this at the end
> ! KSP context for each single block
> call
> PCBJacobiGetSubKSP(pc,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,subksp(1),petsc_err)
> call KSPGetPC(subksp(1),subpc,petsc_err)
> call PCSetType(subpc,PCICC,petsc_err)
> call KSPSetType(subksp(1),KSPPREONLY petsc_err)
> call KSPSetTolerances(subksp(1),tol ,PETSC_DEFAULT_DOUBLE_PRECISION,&
> & PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,petsc_err)
> ! Remove nullspace from the singular system (Check PETSC_NULL)
> call
> MatNullSpaceCreate(MPI_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL,nullspace,petsc_err)
> call KSPSetNullSpace(ksp, nullspace, petsc_err)
> call MatNullSpaceRemove(nullspace, b, PETSC_NULL,petsc_err)
> call KSPSolve(ksp,b,x,petsc_err)
I modified your code slightly. All these options can be provided at runtime:
'-ksp_type cg -pc_type bjacobi -sub_pc_type icc'
Hong
> On 07/13/2012 12:14 PM, Hong Zhang wrote:
> Michele :
>> I need to use the ICC factorization as preconditioner, but I noticed that
>> no parallel version is supported.
>> Is that correct?
> Correct.
>> If so, is there a work around, like building the preconditioner "by
>> hand" by using PETSc functions?
> You may try block jacobi with icc in the blocks '-ksp_type cg -pc_type
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120717/afe5d8c4/attachment-0001.html>
