[petsc-users] Determine if PETSc has been installed with HYPRE support
Umut Tabak
u.tabak at tudelft.nl
Tue Jul 17 10:00:28 CDT 2012
On 07/17/2012 04:04 PM, David Nies wrote:
> Hello all!
> Is there a way to find out if a given PETSc installation has been
> configured and built with '--with-hypre=1'? The background is that I
> want to write an M4 test for our local build system to see if we
> should support PETSc's HYPRE capabilities. Of couse, I could test if
> there is a 'libHYPRE.a' present, but that would only prove that HYPRE
> is installed, not that PETSc supports HYPRE...
> Thank you very much in advance!
> Yours
> -David
