[petsc-users] array still valid after DMDAVecRestoreArrayF90()?
Panruo Wu
pwu at mymail.mines.edu
Mon Jul 16 20:15:48 CDT 2012
How about in the inner block use a different array name
like array2?
Panruo Wu
On Sun, Jul 15, 2012 at 10:39 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Jul 15, 2012 at 11:20 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
>> Hello,
>> For some reason, it would be convenient for me to do something
>> like
>> call DMDAVecGetArrayF90(da, global, array, ierr)
>> ! read-only access to array here.
>> call DMDAVecRestoreArrayF90(da, global, array,ierr)
>> ! read&write access to array here.
>> call DMDAVecRestoreArrayF90(da, global, array, ierr)
> No, it is not okay to lie about the array status.
>> Will this piece of code do what I expect? I wrote a simply
>> program which gave positive answer but I want to know if
>> it's guaranteed to work or only happened to be working.
>> Thanks!
>> Panruo Wu
>> On Sat, Jul 14, 2012 at 1:30 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
>>> Thank you Barry!
>>> Panruo
>>> On Sat, Jul 7, 2012 at 3:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> So long as you have the same boundary types and the same array sizes
>>>> in the i and j direction they give the same distribution.
>>>> Barry
>>>> On Jul 7, 2012, at 3:58 PM, Panruo Wu wrote:
>>>> > Hello,
>>>> > If I create 2 DAs with (almost) identical parameters except DA name
>>>> > and dof like:
>>>> > call DMDACreate2d(PETSC_COMM_WORLD, DMDA_BOUNDARY_GHOSTED,
>>>> > DMDA_BOUNDARY_GHOSTED, &
>>>> > stype, M, N, m, n, dof1, s &
>>>> > PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, &
>>>> > da1, ierr)
>>>> > stype, M, N, m, n, dof2, s &
>>>> > da2, ierr)
>>>> > my question is, will the two DAs have the same distribution scheme?
>>>> > Specifically,
>>>> > will the DMDAGetCorners() give the same results when querying da1 &
>>>> da2?
>>>> > Thanks,
>>>> > Panruo Wu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120716/941c1c31/attachment-0001.html>
