[petsc-users] array still valid after DMDAVecRestoreArrayF90()?
Panruo Wu
pwu at mymail.mines.edu
Sun Jul 15 23:20:48 CDT 2012
Hello,
For some reason, it would be convenient for me to do something
like
call DMDAVecGetArrayF90(da, global, array, ierr)
! read-only access to array here.
call DMDAVecRestoreArrayF90(da, global, array,ierr)
! read&write access to array here.
call DMDAVecRestoreArrayF90(da, global, array, ierr)
Will this piece of code do what I expect? I wrote a simply
program which gave positive answer but I want to know if
it's guaranteed to work or only happened to be working.
Thanks!
Panruo Wu
On Sat, Jul 14, 2012 at 1:30 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
> Thank you Barry!
> Panruo
> On Sat, Jul 7, 2012 at 3:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> So long as you have the same boundary types and the same array sizes
>> in the i and j direction they give the same distribution.
>> Barry
>> On Jul 7, 2012, at 3:58 PM, Panruo Wu wrote:
>> > Hello,
>> > If I create 2 DAs with (almost) identical parameters except DA name
>> > and dof like:
>> > call DMDACreate2d(PETSC_COMM_WORLD, DMDA_BOUNDARY_GHOSTED,
>> > DMDA_BOUNDARY_GHOSTED, &
>> > stype, M, N, m, n, dof1, s &
>> > PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, &
>> > da1, ierr)
>> > stype, M, N, m, n, dof2, s &
>> > da2, ierr)
>> > my question is, will the two DAs have the same distribution scheme?
>> > Specifically,
>> > will the DMDAGetCorners() give the same results when querying da1 & da2?
>> > Thanks,
>> > Panruo Wu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120715/68b04687/attachment.html>
