[petsc-users] About DIVERGED_ITS
    w_ang_temp
    w_ang_temp at 163.com
    Tue Jul 10 22:24:32 CDT 2012
    Thanks very much! I understand.
    I made a test. If the tolerance is large, PETSc says "converged" but the result is "incorrect" for my use
due to the tolerance. While the tolerance is tight, when the rtol reaches a certain value, the result is
not changing and it is not equal to the true value. And PETSc says "diverged". As Jed said, I need to either
increase the number of iterations or use a better preconditioner. And I think the latter is a better way in
my work.
    Thanks.
>At 2012-07-11 01:45:28,"Mark F. Adams" <mark.adams at columbia.edu> wrote:
>On Jul 10, 2012, at 10:51 AM, w_ang_temp wrote:
>    In my opinion, convergence in PETSc is decided by rtol, atol and dtol. The divergent hints just show >that
>in the solving process it does not satisfy the rule. The "right" result may be different from the true result >at
>the several back decimal places(I mean that they may be the same with four decimal places but may be >not
>the same with more decimal places).
>No, If you have an rtol=1.e-30 and atol=1.e-300 then your solution will probably be correct to all decimal places even >though PETSc will say you "diverged".  You can't be too sure about how many digits of accuracy you have with >simple linear algebra arguments unless your system is extremely well conditioned.
>As Jed said if you are doing 10000 iterations are happy with the solution then your tolerances are probably too >tight.  Look at the residual history and see if you are stagnating.
>    Is it right?
>At 2012-07-08 00:28:54,"Mark F. Adams" <mark.adams at columbia.edu> wrote:
>It sounds like your -ksp_rtol is too small.  Experiment with looser tolerances until your solution is >not "correct" to see >how much accuracy you want.
>On Jul 7, 2012, at 12:15 PM, w_ang_temp wrote:
>    Maybe it is a problem of mathematical concept. I compare the result with the true >result which is
>computed and validated by other tools. I think it is right if I get the same result.
>>在 2012-07-08 00:03:21,"Matthew Knepley" <knepley at gmail.com> 写道:
>>On Sat, Jul 7, 2012 at 10:00 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>Hello,
>>    I am a little puzzled that I get the right result while the converged reason says that 'Linear solve >>did not
>>converge due to DIVERGED_ITS iterations 10000'. This infomation means that the >>iterations >reach >the maximum
>>iterations. But the result is right now. So why says 'did not converge'? Can I think >>that the result is >>right and
>>can be used?
>>Obviously, your definition of "right" is not the same as the convergence tolerances >>you are using.
>>    Matt
>>    Thanks.
>>                                            Jim
>What most experimenters take for granted before they begin their experiments is infinitely more >interesting than any results to which their experiments lead.
>-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/7200307f/attachment-0001.html>
