[petsc-users] Declaring struct to represent field for dof > 1 for DM in Fortran
TAY wee-beng
zonexo at gmail.com
Tue Jul 10 14:23:05 CDT 2012
On 10/7/2012 8:48 PM, Randall Mackie wrote:
> On Jul 10, 2012, at 11:29 AM, Jed Brown wrote:
>> On Tue, Jul 10, 2012 at 1:22 PM, TAY wee-beng <zonexo at gmail.com
>> <mailto:zonexo at gmail.com>> wrote:
>> Do you mean DMDAVecGetArrayDOFF90 ? I tried to compile but it
>> gives the error during linking:
>> 1>dm_test2d.obj : error LNK2019: unresolved external symbol
>> DMDAVECGETARRAYDOFF90 referenced in function MAIN__
>> Matt was suggesting that someone should implement this function, it
>> doesn't exist currently.
>> Fortran makes this stuff really painful and we don't know how to make
>> it do something reasonable without depending on your types. You can
>> write your own DMDAVecGetArrayF90WithYourType(), but sadly, it
>> requires some circus tricks to make work. (We can't put this in PETSc
>> because we don't know what your field type is.)
> In my Fortran code, I simply use VecGetArrayF90 on a vector created
> with, for example, DMGetGlobalVector, and it
> works perfectly fine for DOF>1. You might want to look at this example:
> http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex5f90.F.html
> Note that for DOF> 1, the indexing is like vec(3,xs:xe,ys:ye,zs:ze)
> for example..
> Randy
Thanks Randy, I did this as well. But now I'm using DMDAVecGetArrayF90
since it's easier.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120710/7ad2ca49/attachment-0001.html>
