[petsc-users] KSPSetOperators/sub-preconditioner type
Paul T. Bauman
ptbauman at gmail.com
Tue Jul 10 13:34:22 CDT 2012
Greetings,
This question is somewhat related to this thread:
http://lists.mcs.anl.gov/pipermail/petsc-users/2011-August/009583.html but
instead of resurrecting that thread, I decided to start a new one.
Summary: In the libMesh wrapper of PETSc's KSP, a call is made to
KSPSetOperators; I gather this is in order to allow reusing the same
preconditioner, if desired. However, I've noticed that when I use the
following options, the sub-preconditioner type gets reset:
-pc_type bjacobi -sub_pc_type ilu -sub_pc_factor_mat_solver_package superlu
In particular, the first linear solve uses what I asked for, but in all
following linear solves, the petsc ilu solver is used instead of superlu.
If I remove the KSPSetOperators call, everything is peachy.
My question: Does a call need to be made to PCSetFromOptions (or something
similar...) to keep the superlu ilu solver around or would that wipe out
the KSPSetOperators effect? Is this a PETSc bug? Other?
This is with petsc-3.3-p1.
Thanks for your time.
Best,
Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120710/a9b66b1b/attachment.html>
