[petsc-users] About DIVERGED_ITS
Tue Jul 10 12:12:13 CDT 2012
Possibilities (not mutually exclusive)
1. the convergence tolerance is too tight to converge in double precision
arithmetic, so the solver is stagnating (you could try
--with-precision=__float128)
2. the tolerance is too tight to converge in 10000 iterations (either
increase the number of iterations or use a better preconditioner
3. the tolerance is tighter than necessary to get a solution that is "right
enough" for you (try loosening the tolerance)
On Tue, Jul 10, 2012 at 9:51 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>     In my opinion, convergence in PETSc is decided by rtol, atol and dtol.
> The divergent hints just show that
> in the solving process it does not satisfy the rule. The "right" result
> may be different from the true result at
> the several back decimal places(I mean that they may be the same with four
> decimal places but may be not
> the same with more decimal places).
>     Is it right?
> >At 2012-07-08 00:28:54,"Mark F. Adams" <mark.adams at columbia.edu> wrote:
> >It sounds like your -ksp_rtol is too small.  Experiment with looser
> tolerances until your solution is not "correct" to see >how much accuracy
> you want.
>  >On Jul 7, 2012, at 12:15 PM, w_ang_temp wrote:
>  >    Maybe it is a problem of mathematical concept. I compare the result
> with the true result which is
> >computed and validated by other tools. I think it is right if I get the
> same result.
> >>在 2012-07-08 00:03:21,"Matthew Knepley" <knepley at gmail.com> 写道:
> >>On Sat, Jul 7, 2012 at 10:00 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>  >>Hello,
>> >>    I am a little puzzled that I get the right result while the
>> converged reason says that 'Linear solve >>did not
>> >>converge due to DIVERGED_ITS iterations 10000'. This infomation means
>> that the iterations >reach >the maximum
>> >>iterations. But the result is right now. So why says 'did not
>> converge'? Can I think that the result is >>right and
>> >>can be used?
> >>Obviously, your definition of "right" is not the same as the convergence
> tolerances you are using.
> >>    Matt
>> >>    Thanks.
>> >>                                            Jim
> >What most experimenters take for granted before they begin their
> experiments is infinitely more >interesting than any results to which their
> experiments lead.
> >-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120710/cfc59962/attachment-0001.html>
