[petsc-users] Declaring struct to represent field for dof > 1 for DM in Fortran
Matthew Knepley
knepley at gmail.com
Tue Jul 10 11:05:33 CDT 2012
On Tue, Jul 10, 2012 at 11:03 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Yours sincerely,
> TAY wee-beng
> On 10/7/2012 2:07 PM, Matthew Knepley wrote:
> On Tue, Jul 10, 2012 at 5:39 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I read in the manual in page 50 that it's recommended to declare struct
>> to represent field for dof > 1 for DM.
> We mean C struct. C makes it easy (just use a pointer type cast).
> Fortran makes it hard unfortunately.
> Matt
> Ok, I'll try to use another mtd.
> Btw, if I declare:
> *PetscScalar,pointer :: array2(:,:,:)
> with DMDACreate2d using dof = 2,
> call DMDAVecGetArrayF90(da,x_local,array2,ierr)
> access array2 ....
> call DMDAVecRestoreArrayF90(da,x_local,array2,ierr)*
> How is the memory for "array2" allocated ? Is it allocated all the time,
> or only between the DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90?
> Also, can I "reuse" array2? For e.g., now for y_local:
> *call DMDAVecGetArrayF90(da,y_local,array2,ierr)
> access array2 ....* *
> call DMDAVecRestoreArrayF90(da,y_local,array2,ierr)*
The right thing to do here is to implement DMDAVecGetArratDOFF90().
Matt
> Thank you!
>> I'm using Fortran and for testing, I use dof = 1 and write as:
>> *type field
>> **PetscScalar** u (or real(8) :: u)
>> end type field
>> type(field), pointer :: field_u(:,:)*
>> When I tried to use :
>> *call DMDAVecGetArrayF90(da,x_local,field_u,ierr)*
>> I got the error : There is no matching specific subroutine for this
>> generic subroutine call. [DMDAVECGETARRAYF90]
>> The da, x_local has been defined with the specific DM routines. It worked
>> if I use :
>> *PetscScalar,pointer :: array(:,:) and
>> call DMDAVecGetArrayF90(da,x_local,array,ierr)*
>> May I know what did I do wrong?
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120710/2c4d58cd/attachment-0001.html>
