[petsc-users] MPICH error in KSPSolve
John Mousel
john.mousel at gmail.com
Mon Jul 9 14:41:31 CDT 2012
Can you clarify what you mean by null-space cleaning. I just run SOR on
the coarse grid.
On Mon, Jul 9, 2012 at 11:52 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Jul 9, 2012, at 12:39 PM, John Mousel wrote:
> Mark,
> The problem is indeed non-symmetric. We went back and forth in March about
> this problem. I think we ended up concluding that the coarse size couldn't
> get too small or the null-space presented problems.
> Oh its singular. I forget what the issues were but an iterative coarse
> grid solver should be fine for singular problems, perhaps with null space
> cleaning if the kernel is sneaking in. Actually there is an SVD coarse
> grid solver:
> -mg_coarse_pc_type svd
> That is the most robust.
> When I did get it to work, I tried to scale it up, and on my local
> university cluster, it seemed to just hang when the core counts got above
> something like 16 cores. I don't really trust that machine though.
> That's the machine. GAMG does have some issues but I've not seen it hang.
> It's new and has been plagued by hardware incompatability issues since day
> 1. I could re-examine this on Kraken. Also, what option are you talking
> about with ML. I thought I had tried all the -pc_ml_CoarsenScheme options,
> but I could be wrong.
> This sounds like the right one. I try to be careful in my solvers to be
> invariant to subdomain shapes and sizes and I think Ray Tuminaro (ML
> developer) at least has options that should be careful about this also.
> But I don't know much about what they are deploying these days.
> Mark
> John
> On Mon, Jul 9, 2012 at 11:30 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> What problems are you having again with GAMG? Are you problems
>> unsymmetric?
>> ML has several coarsening strategies available and I think the default
>> does aggregation locally and does not aggregate across processor
>> subdomains. If you have poorly shaped domains then you want to use a
>> global coarsening method (these are not expensive).
>> Mark
>> On Jul 9, 2012, at 12:17 PM, John Mousel wrote:
>> Mark,
>> I still haven't had much luck getting GAMG to work consistently for my
>> Poisson problem. ML seems to work nicely on low core counts, but I have a
>> problem where I can get long thin portions of grid on some processors
>> instead of nice block like chunks at high core counts, which leads to a
>> pretty tough time for ML.
>> John
>> On Mon, Jul 9, 2012 at 10:58 AM, John Mousel <john.mousel at gmail.com>wrote:
>>> Getting rid of the Hypre option seemed to be the trick.
>>> On Mon, Jul 9, 2012 at 10:40 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>>> Google PTL_NO_SPACE and you will find some NERSC presentations on how
>>>> to go about fixing this. (I have run into these problems years ago but
>>>> forget the issues)
>>>> Also, I would try running with a Jacobi solver to see if that fixes the
>>>> problem. If so then you might try
>>>> -pc_type gamg
>>>> -pc_gamg_agg_nsmooths 1
>>>> -pc_gamg_type agg
>>>> This is a built in AMG solver so perhaps it plays nicer with resources
>>>> Mark
>>>> On Jul 9, 2012, at 10:57 AM, John Mousel wrote:
>>>> > I'm running on Kraken and am currently working with 4320 cores. I get
>>>> the following error in KSPSolve.
>>>> > [2711]:
>>>> (/ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046)
>>>> PtlMEInsert failed with error : PTL_NO_SPACE
>>>> > MHV_exe:
>>>> /ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046:
>>>> MPIDI_CRAY_ptldev_desc_pkt: Assertion `0' failed.
>>>> > forrtl: error (76): Abort trap signal
>>>> > Image PC Routine Line
>>>> Source
>>>> > MHV_exe 00000000014758CB Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000182ED43 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 0000000001829460 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000017EDE3E Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000017B3FE6 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000017B3738 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000017B2B12 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000017B428F Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000177FCE1 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 0000000001590A43 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000014F909B Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000014FF53B Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 00000000014A4E25 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 0000000001487D57 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000147F726 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000137A8D3 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 0000000000E97BF2 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000098EAF1 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 0000000000989C20 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000097A9C2 Unknown Unknown
>>>> Unknown
>>>> > MHV_exe 000000000082FF2D axbsolve_ 539
>>>> PetscObjectsOperations.F90
>>>> > This is somewhere in KSPSolve. Is there an MPICH environment variable
>>>> that needs tweaking? I couldn't really find much on this particular error.
>>>> > The solver is BiCGStab with Hypre as a preconditioner.
>>>> > -ksp_type bcgsl -pc_type hypre -pc_hypre_type boomeramg -ksp_monitor
>>>> > Thanks,
>>>> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120709/04573f2f/attachment-0001.html>
