[petsc-users] MPICH error in KSPSolve
John Mousel
john.mousel at gmail.com
Mon Jul 9 11:39:34 CDT 2012
Mark,
The problem is indeed non-symmetric. We went back and forth in March about
this problem. I think we ended up concluding that the coarse size couldn't
get too small or the null-space presented problems. When I did get it to
work, I tried to scale it up, and on my local university cluster, it seemed
to just hang when the core counts got above something like 16 cores. I
don't really trust that machine though. It's new and has been plagued by
hardware incompatability issues since day 1. I could re-examine this on
Kraken. Also, what option are you talking about with ML. I thought I had
tried all the -pc_ml_CoarsenScheme options, but I could be wrong.
John
On Mon, Jul 9, 2012 at 11:30 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> What problems are you having again with GAMG? Are you problems
> unsymmetric?
> ML has several coarsening strategies available and I think the default
> does aggregation locally and does not aggregate across processor
> subdomains. If you have poorly shaped domains then you want to use a
> global coarsening method (these are not expensive).
> Mark
> On Jul 9, 2012, at 12:17 PM, John Mousel wrote:
> Mark,
> I still haven't had much luck getting GAMG to work consistently for my
> Poisson problem. ML seems to work nicely on low core counts, but I have a
> problem where I can get long thin portions of grid on some processors
> instead of nice block like chunks at high core counts, which leads to a
> pretty tough time for ML.
> John
> On Mon, Jul 9, 2012 at 10:58 AM, John Mousel <john.mousel at gmail.com>wrote:
>> Getting rid of the Hypre option seemed to be the trick.
>> On Mon, Jul 9, 2012 at 10:40 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> Google PTL_NO_SPACE and you will find some NERSC presentations on how to
>>> go about fixing this. (I have run into these problems years ago but forget
>>> the issues)
>>> Also, I would try running with a Jacobi solver to see if that fixes the
>>> problem. If so then you might try
>>> -pc_type gamg
>>> -pc_gamg_agg_nsmooths 1
>>> -pc_gamg_type agg
>>> This is a built in AMG solver so perhaps it plays nicer with resources
>>> Mark
>>> On Jul 9, 2012, at 10:57 AM, John Mousel wrote:
>>> > I'm running on Kraken and am currently working with 4320 cores. I get
>>> the following error in KSPSolve.
>>> > [2711]:
>>> (/ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046)
>>> PtlMEInsert failed with error : PTL_NO_SPACE
>>> > MHV_exe:
>>> /ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046:
>>> MPIDI_CRAY_ptldev_desc_pkt: Assertion `0' failed.
>>> > forrtl: error (76): Abort trap signal
>>> > Image PC Routine Line
>>> Source
>>> > MHV_exe 00000000014758CB Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000182ED43 Unknown Unknown
>>> Unknown
>>> > MHV_exe 0000000001829460 Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000017EDE3E Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000017B3FE6 Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000017B3738 Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000017B2B12 Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000017B428F Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000177FCE1 Unknown Unknown
>>> Unknown
>>> > MHV_exe 0000000001590A43 Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000014F909B Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000014FF53B Unknown Unknown
>>> Unknown
>>> > MHV_exe 00000000014A4E25 Unknown Unknown
>>> Unknown
>>> > MHV_exe 0000000001487D57 Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000147F726 Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000137A8D3 Unknown Unknown
>>> Unknown
>>> > MHV_exe 0000000000E97BF2 Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000098EAF1 Unknown Unknown
>>> Unknown
>>> > MHV_exe 0000000000989C20 Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000097A9C2 Unknown Unknown
>>> Unknown
>>> > MHV_exe 000000000082FF2D axbsolve_ 539
>>> PetscObjectsOperations.F90
>>> > This is somewhere in KSPSolve. Is there an MPICH environment variable
>>> that needs tweaking? I couldn't really find much on this particular error.
>>> > The solver is BiCGStab with Hypre as a preconditioner.
>>> > -ksp_type bcgsl -pc_type hypre -pc_hypre_type boomeramg -ksp_monitor
>>> > Thanks,
>>> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120709/37f6936f/attachment-0001.html>
