[petsc-users] MPICH error in KSPSolve
John Mousel
john.mousel at gmail.com
Mon Jul 9 11:17:11 CDT 2012
Mark,
I still haven't had much luck getting GAMG to work consistently for my
Poisson problem. ML seems to work nicely on low core counts, but I have a
problem where I can get long thin portions of grid on some processors
instead of nice block like chunks at high core counts, which leads to a
pretty tough time for ML.
John
On Mon, Jul 9, 2012 at 10:58 AM, John Mousel <john.mousel at gmail.com> wrote:
> Getting rid of the Hypre option seemed to be the trick.
> On Mon, Jul 9, 2012 at 10:40 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> Google PTL_NO_SPACE and you will find some NERSC presentations on how to
>> go about fixing this. (I have run into these problems years ago but forget
>> the issues)
>> Also, I would try running with a Jacobi solver to see if that fixes the
>> problem. If so then you might try
>> -pc_type gamg
>> -pc_gamg_agg_nsmooths 1
>> -pc_gamg_type agg
>> This is a built in AMG solver so perhaps it plays nicer with resources ...
>> Mark
>> On Jul 9, 2012, at 10:57 AM, John Mousel wrote:
>> > I'm running on Kraken and am currently working with 4320 cores. I get
>> the following error in KSPSolve.
>> > [2711]:
>> (/ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046)
>> PtlMEInsert failed with error : PTL_NO_SPACE
>> > MHV_exe:
>> /ptmp/ulib/mpt/nightly/5.3/120211/mpich2/src/mpid/cray/src/adi/ptldev.c:2046:
>> MPIDI_CRAY_ptldev_desc_pkt: Assertion `0' failed.
>> > forrtl: error (76): Abort trap signal
>> > Image PC Routine Line
>> Source
>> > MHV_exe 00000000014758CB Unknown Unknown
>> Unknown
>> > MHV_exe 000000000182ED43 Unknown Unknown
>> Unknown
>> > MHV_exe 0000000001829460 Unknown Unknown
>> Unknown
>> > MHV_exe 00000000017EDE3E Unknown Unknown
>> Unknown
>> > MHV_exe 00000000017B3FE6 Unknown Unknown
>> Unknown
>> > MHV_exe 00000000017B3738 Unknown Unknown
>> Unknown
>> > MHV_exe 00000000017B2B12 Unknown Unknown
>> Unknown
>> > MHV_exe 00000000017B428F Unknown Unknown
>> Unknown
>> > MHV_exe 000000000177FCE1 Unknown Unknown
>> Unknown
>> > MHV_exe 0000000001590A43 Unknown Unknown
>> Unknown
>> > MHV_exe 00000000014F909B Unknown Unknown
>> Unknown
>> > MHV_exe 00000000014FF53B Unknown Unknown
>> Unknown
>> > MHV_exe 00000000014A4E25 Unknown Unknown
>> Unknown
>> > MHV_exe 0000000001487D57 Unknown Unknown
>> Unknown
>> > MHV_exe 000000000147F726 Unknown Unknown
>> Unknown
>> > MHV_exe 000000000137A8D3 Unknown Unknown
>> Unknown
>> > MHV_exe 0000000000E97BF2 Unknown Unknown
>> Unknown
>> > MHV_exe 000000000098EAF1 Unknown Unknown
>> Unknown
>> > MHV_exe 0000000000989C20 Unknown Unknown
>> Unknown
>> > MHV_exe 000000000097A9C2 Unknown Unknown
>> Unknown
>> > MHV_exe 000000000082FF2D axbsolve_ 539
>> PetscObjectsOperations.F90
>> > This is somewhere in KSPSolve. Is there an MPICH environment variable
>> that needs tweaking? I couldn't really find much on this particular error.
>> > The solver is BiCGStab with Hypre as a preconditioner.
>> > -ksp_type bcgsl -pc_type hypre -pc_hypre_type boomeramg -ksp_monitor
>> > Thanks,
>> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120709/a9921e6a/attachment.html>
