[petsc-users] vecview problem
Klaij, Christiaan C.Klaij at marin.nl
Mon Jul 9 08:50:44 CDT 2012
I'm having a segmentation fault with vecview in fortran90
with this program. Am I doing something wrong?
$ cat bug.F90
module bug
  use petscksp
  implicit none
#include "finclude/petsckspdef.h"
  PetscErrorCode, public :: ierr
  Vec, private :: x
  public bugSubroutine
contains
  subroutine bugSubroutine()
    call setVector()
    call VecView(x,PETSC_VIEWER_DEFAULT,ierr); CHKERRQ(ierr)
  end subroutine bugSubroutine
  subroutine setVector()
    call VecCreate(PETSC_COMM_WORLD,x,ierr); CHKERRQ(ierr)
    call VecSetSizes(x,PETSC_DECIDE,5,ierr); CHKERRQ(ierr)
    call VecSetType(x,VECMPI,ierr); CHKERRQ(ierr)
  end subroutine setVector
end module bug
program testBug
  use bug
  use petscksp
  implicit none
  call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
  call bugSubroutine();
  call PetscFinalize(ierr)
end program testBug
$ mpiexec -n 1 ./bug
Vector Object: 1 MPI processes
  type: mpi
Process [0]
0
0
0
0
0
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] VecView line 747 /home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/src/vec/vec/interface/vector.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 1, Fri Jun 15 09:30:49 CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./bug on a linux_64b named lin0133 by cklaij Mon Jul  9 15:46:34 2012
[0]PETSC ERROR: Libraries linked from /home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/linux_64bit_debug/lib
[0]PETSC ERROR: Configure run at Wed Jun 20 12:08:20 2012
[0]PETSC ERROR: Configure options --with-mpi-dir=/opt/refresco/libraries_cklaij/openmpi-1.4.5 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-hypre-include=/opt/refresco/libraries_cklaij/hypre-2.7.0b/include --with-hypre-lib=/opt/refresco/libraries_cklaij/hypre-2.7.0b/lib/libHYPRE.a --with-ml-include=/opt/refresco/libraries_cklaij/ml-6.2/include --with-ml-lib=/opt/refresco/libraries_cklaij/ml-6.2/lib/libml.a --with-blas-lapack-dir=/opt/intel/mkl
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
(gdb) run
Starting program: /home/CKlaij/Programming/PETSc/Laplace/bug
[Thread debugging using libthread_db enabled]
  type: mpi
Process [0]
0
0
0
0
0
Program received signal SIGSEGV, Segmentation fault.
0x000000000043f7ee in VecView (vec=0xd8b1f0, viewer=0x69706d00000000)
    at /home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/src/vec/vec/interface/vector.c:753
753       PetscValidHeaderSpecific(viewer,PETSC_VIEWER_CLASSID,2);
(gdb) bt
#0  0x000000000043f7ee in VecView (vec=0xd8b1f0, viewer=0x69706d00000000)
#1  0x00000000004319e8 in vecview_ (x=0xb56e20, vin=0x822788, ierr=0xb56e38)
    at /home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/src/vec/vec/interface/ftn-custom/zvectorf.c:56
#2  0x000000000042c936 in bug_mp_bugsubroutine_ ()
#3  0x000000000042cafb in testbug () at bug.F90:37
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
