[petsc-users] error compiling on MPI_Win
Matthew Knepley
knepley at gmail.com
Thu Jul 5 16:09:48 CDT 2012
1) Make sure you have updated BuildSystem:
cd $PETSC_DIR/config/BuildSystem
hg pull -u
2) Reconfigure and rebuild
3) If its still broken, send configure.log to petsc-maint at mcs.anl.gov
Matt
On Thu, Jul 5, 2012 at 3:02 PM, hbui <hgbk2008 at gmail.com> wrote:
> Hi
> When compiling a small petsc example, i got an error as such:
> In file included from /opt/petsc/petsc-dev/include/**petscis.h:8:0,
> from /opt/petsc/petsc-dev/include/**petscvec.h:9,
> from /opt/petsc/petsc-dev/include/**petscmat.h:6,
> from /opt/petsc/petsc-dev/include/**petscdm.h:6,
> from /opt/petsc/petsc-dev/include/**petscpc.h:6,
> from /opt/petsc/petsc-dev/include/**petscksp.h:6,
> from ../PETScSolver.h:14,
> from ../PETScSolver.cpp:8:
> /opt/petsc/petsc-dev/include/**petscsf.h:69:119: error: 'MPI_Win' has not
> been declared
> /opt/petsc/petsc-dev/include/**petscsf.h:70:80: error: 'MPI_Win' has not
> been declared
> /opt/petsc/petsc-dev/include/**petscsf.h:71:105: error: 'MPI_Win' has not
> been declared
> In file included from /opt/petsc/petsc-dev/include/**petscvec.h:482:0,
> /opt/petsc/petsc-dev/include/**petsc-private/vecimpl.h:498:3: error:
> 'MPI_Win' does not name a type
> I search over the mailing list and see a post which related to this error
> but i didn't quite understand the answer and the user has also discontinued
> the thread.
> http://lists.mcs.anl.gov/**pipermail/petsc-dev/2011-**November/006227.html<http://lists.mcs.anl.gov/pipermail/petsc-dev/2011-November/006227.html>
> I tried to trace back the definition of MPI_Win struct and see as below:
> #ifndef PETSC_HAVE_MPI_WIN_CREATE
> #define PETSC_HAVE_MPI_WIN_CREATE 1
> #endif
> #if !defined(PETSC_HAVE_MPI_WIN_**CREATE) /* The intent here is to be
> able to compile even without a complete MPI. */
> typedef struct MPI_Win_MISSING *MPI_Win;
> #endif
> For some reason the ./configure define PETSC_HAVE_MPI_WIN_CREATE and
> compiler skip the MPI_Win definition. However, i also don't know where the
> struct MPI_Win_MISSING is defined.
> Please advise the method to resolve this compilation error.
> My system is Ubuntu 12.04, Gcc 4.6.3.
> Regards,
> Giang Bui
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120705/f744c4ef/attachment.html>
