[petsc-users] Adapting MatMult and PCMG functions in matrix-free method.
Thu Jul 5 13:37:25 CDT 2012
On Jul 5, 2012, at 11:40 AM, domenico lahaye wrote:
> Dear PETSc developers,
>   Thank you for your support to Abdul.
>    We are in the process of developing a multilevel
> Krylov solver for the Helmholtz equation. Abdul
> has implemented Algorithm I for this purpose.
> We next would like to implement Algorithm II.
> Algorithm || amounts to replacing every occurrence
> of the system matrix $A$ in Algorithm I by
> $M^{-1} A$. This replacement should occur on all
> levels. We thought of two ways to realize this
> replacement.
> 1) We thought of adopting a matrix-free approach,
> and to plug in the operation with  $M^{-1}$ there.
> This would require a ksp context inside MatMult.
> We wonder whether this a approach is feasible to
> take.
   If you truly are simply replacing a multiply by A everywhere with a approx. multiply by M^{-1}A then 1 is the easier AND more elegant approach. Simply create a MATSHELL and put in its context a struct continuing the A and the KSP used so approximately solve the M^{-1}A.
> 2) The other approach would by to implement a
> customized pcmg preconditioner that we can adapt
> to our needs. This could be a more elegant approach,
> at the cost of doing more work. Is the assumption
> that the second approach is more elegant correct
> and would you be able to give advice on how to tackle
> this approach?
>   Kind wishes, Domenico.
> ----- Forwarded Message -----
> From: Matthew Knepley <knepley at gmail.com>
> To: Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>; PETSc users list <petsc-users at mcs.anl.gov>
> Sent: Thursday, 5 July 2012, 15:45
> Subject: Re: [petsc-users] Adapting MatMult and PCMG functions in matrix-free method.
> On Thu, Jul 5, 2012 at 7:34 AM, Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk> wrote:
> Dear developers and users,
> Summer greetings.
> We have few question listen below:
> 1.
> The first question is about adapting " MatMult " function in matrix-free method.
> We intend to incorporate a KSP context inside "MatMult" . The immediate question is how to
> provide more than one matrices as input.
> You provide extra data through the context for the MATSHELL
> Is this idea of incorporating a KSP context inside "MatMult" function workable ? Does it make any confrontation
> with philosophy of development of Petsc. ?
> I am not sure you want this. Do you think PCKSP can do what you want? There is not enough information here to help us answer.
> 2.
> An other advance level feedback is needed.
>  Re-implementing PCMG function { mg.c } will lead any violation of philosophy of Petsc-development ??
> Again, there is not enough information. Can you do what you want by just replacing the monitors?
>   Thanks,
>      Matt
> 3.
> Which one of the above both is more elegant and feasible to work on ?
> Thanking in anticipation,
> Abdul
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
