[petsc-users] Getting 2d array with updated ghost values from DM global vector
TAY wee-beng
zonexo at gmail.com
Mon Jul 2 08:41:17 CDT 2012
On 2/7/2012 2:49 PM, Matthew Knepley wrote:
> On Mon, Jul 2, 2012 at 3:58 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> Hi,
> I have used DMDACreate2d for my code and then use:
> call
> DMLocalToGlobalBegin(da,b_rhs_semi_local,INSERT_VALUES,b_rhs_semi_global,ierr)
> call
> DMLocalToGlobalEnd(da,b_rhs_semi_local,INSERT_VALUES,b_rhs_semi_global,ierr)
> to construct the global DM vector b_rhs_semi_global
> Now I want to get the values with ghost values in a 2d array
> locally which is declared as:
> real(8), allocatable :: array2d(:,:)
> I guess I should use DMDAGetGhostCorners to get the corressponding
> indices and allocate it. But what should I do next? How can I use
> something like VecGetArrayF90 to get to the pointer to access the
> local vector?
> I can't use DMDAVecGetArrayF90/DMDAVecRestoreArrayF90 since I'm
> using intel fortran and they can't work. I can't use gfortran at
> the moment since I've problems with HYPRE with gfortran in 3D.
> Are you certain of this? That used to be true, but the current version
> should work for any F90.
> Matt
I just tested 3.3-p1 and it still doesn't work (example ex11f90 in dm).
Is there a chance petsc-dev can work?
> Thanks
> Yours sincerely,
> TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120702/66ad7cc4/attachment.html>
