[petsc-users] generate entries on 'wrong' process
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Jan 20 11:36:17 CST 2012
On Fri, Jan 20, 2012 at 11:31, Wen Jiang <jiangwen84 at gmail.com> wrote:
> The serial job is running without any problems and never stalls. Actually
> the parallel jobs also running successfully on distributed-memory desktop
> or on single node of cluster. It will get stuck if it is running on more
> than one compute node(now it is running on two nodes). Both the serial job
> and parallel job (running on distributed or cluster) I mentioned before
> have the same size(dofs). But If I ran a smaller job on cluster with two
> nodes, it might not get stuck and work fine.
> As you said before, I add MAT_ASSEMBLY_FLUSH after every element stiffness
> matrix is inserted.
This will deadlock unless the number of elements is *exactly* the same on
every process.
> I got the output like below, and it gets stuck too.
When it "gets stuck", attach a debugger and get stack traces.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120120/4937f69b/attachment.htm>
