[petsc-users] A few questions about hdf5 viewer
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Thu Jan 19 18:52:11 CST 2012
Then give 0 sizes on everything but 0.
Thanks Matt. Or can I just do everything all those operation on processor
zero?
Mohamad
On Thu, Jan 19, 2012 at 4:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 19, 2012 at 6:44 PM, Mohamad M. Nasr-Azadani <mmnasr at gmail.com
> > wrote:
>> You should just create a parallel Vec to hold the 1D data.
>> DAGetLocalInfo() tells you all the local sizes.
>> Thanks Matt. But I am not sure how this would help since PETSC_COMM_WORLD
>> includes all the processors and in all three directions whereas the 1-D
>> data is only the size of Nx points.
>> This vector is not big at all, I could even create is on one processor.
>> The only concern that I have is
>> can I create an *.h5 file using PETSC_COMM_WORLD, dump the data, close
>> the file and then, re-open the file (append mode) with a different viewer
>> created via PETSC_COMM_SELF, and dump the coordinates vector to the end of
>> it? Of course, I only call PETSC_COMM_SELF on processor zero.
>   Matt
>> Thanks,
>> M
>> On Thu, Jan 19, 2012 at 4:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Thu, Jan 19, 2012 at 6:08 PM, Mohamad M. Nasr-Azadani <
>>> mmnasr at gmail.com> wrote:
>>>> Thanks Jed.
>>>> My solution to that was to create a 1D vector local to for instance
>>>> processor zero that holds all the coordinates. Then after I dumped all the
>>>> parallel data to the *.h5 file, I create another viewer on processor zero
>>>> or PETSC_COMM_SELF and dump that new vector including tHe coordinates to
>>>> the end of the existing file.
>>>> Do you think that should be possible?
>>>    Matt
>>>> Thanks,
>>>> Mohamad
>>>> On Thu, Jan 19, 2012 at 4:02 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> On Thu, Jan 19, 2012 at 18:00, Mohamad M. Nasr-Azadani <
>>>>>> What I need is just to add 3 1-D arrays of (x[Nx]+y[Ny]+z[Nz])
>>>>>> including the grid coordinates to the end of the *.h5 file and then later
>>>>>> on, I can use any visualization software to load the data using those
>>>>>> coordinates. I am using orthogonal grid, that's why I don't need  all the
>>>>>> (x,y,z) coordinates for each cell.
>>>>> If you want this special case, you have to manage it by hand.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120119/8047c30e/attachment.htm>
