[petsc-users] A few questions about hdf5 viewer
Mohamad M. Nasr-Azadani
mmnasr at gmail.com
Thu Jan 19 18:08:52 CST 2012
Thanks Jed.
My solution to that was to create a 1D vector local to for instance
processor zero that holds all the coordinates. Then after I dumped all the
parallel data to the *.h5 file, I create another viewer on processor zero
or PETSC_COMM_SELF and dump that new vector including tHe coordinates to
the end of the existing file.
Do you think that should be possible?
Mohamad
On Thu, Jan 19, 2012 at 4:02 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jan 19, 2012 at 18:00, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>> What I need is just to add 3 1-D arrays of (x[Nx]+y[Ny]+z[Nz]) including
>> the grid coordinates to the end of the *.h5 file and then later on, I can
>> use any visualization software to load the data using those coordinates. I
>> am using orthogonal grid, that's why I don't need all the
>> (x,y,z) coordinates for each cell.
> If you want this special case, you have to manage it by hand.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120119/a28c714d/attachment.htm>
