[petsc-users] [petsc-maint #101696] complex + float128
Xavier Garnaud
xavier.garnaud at ladhyx.polytechnique.fr
Sun Jan 15 05:54:49 CST 2012
Thank you for your help.
quadmath.h contains quad complex functions. I naively added the functions
for quad complex. The beginning of the compilation works, but then it fails
with an MPI related error. I will contact you again when i manage to make
it work,
Sincerely,
Xavier
On Mon, Jan 9, 2012 at 8:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> We've never tried to do this.
> First you need to check if quadmath.h has quad complex stuff in it? If
> it does you need to add into petscmath.h the quad complex bindings for all
> the various math operations like PetscScalar and PetscSqrtScalar() etc
> Barry
> On Jan 9, 2012, at 12:05 PM, Xavier Garnaud wrote:
> > I am trying to build PETSc with complex number and quadruple precision,
> but
> > I get an error at the compiling stage. I do not get this error when I do
> > the same using real numbers. Are complex numbers incompatible with
> > quadruple precision?
> > Thank you very much,
> > Sincerely,
> > Xavier
> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120115/7719062b/attachment-0001.htm>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120115/7719062b/attachment-0001.h>
