[petsc-users] metis for dev version of petsc
Matthew Knepley
knepley at gmail.com
Fri Jan 13 12:56:35 CST 2012
On Fri, Jan 13, 2012 at 11:33 AM, Sean Farley <sean at mcs.anl.gov> wrote:
> Recently, we started using the development version for some testing. This
>> needs a more recent version of metis: ****
>> METIS_SetDefaultOptions(&options[0]);****
>> METIS_PartGraphKway(&nCells, &ncon,
>> &ia[0],&ja[0],&vwgt[0],&vsize[0],&adjwgt[0],&nParts,&tpwgts[0],&ubvec[0],
>> &options[0],&edgecut,&part[0]);****
>> This has the same function name but with different argument list.****
>> We noticed that the latest version does not partition properly as before
>> : we get just one cell in the 0th partition.****
>> Any inputs on this?
> What are you setting for options? i.e. are you trying to use the default
> parameters or do you have your own weights?
To follow up on Sean's note, is there a reason that this partitioning
problem does not fit into MatPartitioning? If not,
we would be very interested in extending our interface to support it.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120113/0eb2c42c/attachment.htm>
