[petsc-users] 3.2-p6
Satish Balay
balay at mcs.anl.gov
Wed Jan 11 10:08:55 CST 2012
You should see the links to the p6 tarballs at the download webpage:
http://www.mcs.anl.gov/petsc/download/index.html
[if you still see p5 links - hit the 'reload' button of your browser]
The direct links are:
http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-3.2-p6.tar.gz
http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-lite-3.2-p6.tar.gz
Satish
On Wed, 11 Jan 2012, Parker, Andrew (UK Filton) wrote:
> Ok Great thank, I can't see it on the main web page, should I look
> elsewhere?
> Cheers,
> Andy
> -----Original Message-----
> From: petsc-users-bounces at mcs.anl.gov
> [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: 11 January 2012 16:01
> To: PETSc users list
> Subject: Re: [petsc-users] 3.2-p6
> *** WARNING ***
> This message has originated outside your organisation,
> either from an external partner or the Global Internet.
> Keep this in mind if you answer this message.
> To report a suspicious email, follow the instructions
> on the Global Intranet at "<How We Work> / <Security>"
> petsc-3.2-p6 tarball is now available for download.
> And yes - it should have the patch you mention.
> Satish
> > Hi,
> > Just before Christmas I was kindly provided a patch for the pbjacob
> > method for 7x7 matrices: pbjacobi.patch. I applied this to 3.2-p5 at
> it
> > worked fine, but I wonder when/if it will make it to a release and if
> so
> > will it be on p6? When is p6 scheduled as I need to plan an internal
> > release based on this?
> > Cheers again,
> > Andy
> > This email and any attachments are confidential to the intended
> > recipient and may also be privileged. If you are not the intended
> > recipient please delete it from your system and notify the sender.
> > You should not copy it or use it for any purpose nor disclose or
> > distribute its contents to any other person.
