[petsc-users] 3.2-p6
Wed Jan 11 10:01:29 CST 2012
petsc-3.2-p6 tarball is now available for download.
And yes - it should have the patch you mention.
Satish
On Wed, 11 Jan 2012, Parker, Andrew (UK Filton) wrote:
> Hi,
> Just before Christmas I was kindly provided a patch for the pbjacob
> method for 7x7 matrices: pbjacobi.patch.  I applied this to 3.2-p5 at it
> worked fine, but I wonder when/if it will make it to a release and if so
> will it be on p6?  When is p6 scheduled as I need to plan an internal
> release based on this?
> Cheers again,
> Andy
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
