[petsc-users] How/where to update DASetStencilWidth() info
Fri Jan 6 16:34:55 CST 2012
On Fri, Jan 6, 2012 at 16:32, Xuefeng Li <li at loyno.edu> wrote:
> However, is there a way to change/adjust the stencil width
> AFTER the DA has been created and set up to a DMMG? Or,
> in general, can we attach different DA objects to a DMMG
> at different times?
1. Please do not use DMMG, it has been almost completely removed.
2. You can create a new DM if you need to change its layout.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120106/522a68a7/attachment.htm>
