[petsc-users] Error in VecAssemeblyBegin after VecView
Barry Smith
bsmith at mcs.anl.gov
Wed Jan 4 16:18:24 CST 2012
Hannes,
Thanks for reporting the problem. It is a bug in our handling of PETSC_VIEWER_ASCII_MATLAB in parallel. I have fixed the repository copy in both petsc-3.2 and petsc-dev It will be fixed in the next patch release of 3.2 or Satish can send you the patch file; just ask for it at petsc-maint at mcs.anl.gov
Barry
> Hannes
On Jan 4, 2012, at 11:59 AM, Johannes.Huber at unibas.ch wrote:
> Hi all,
> thanks a lot for you help.
> I tracked the problem down to a minimal program and found, that it looks like I'm doing something wrong when using the matlab format. Here is the minimal program:
> #include <petscvec.h>
> static char help[] = "Matlab output.\n\n";
> int main (int argc, char** argv)
> PetscInitialize(&argc,&argv,(char*)0,help);
> Vec b;
> PetscInt ierr;
> int r;
> MPI_Comm_rank(PETSC_COMM_WORLD,&r);
> ierr=VecCreate(PETSC_COMM_WORLD,&b); CHKERRQ(ierr);
> ierr=VecSetSizes(b,10,PETSC_DECIDE); CHKERRQ(ierr);
> ierr=VecSetFromOptions(b); CHKERRQ(ierr);
> ierr=VecZeroEntries(b); CHKERRQ(ierr);
> ierr=VecAssemblyBegin(b); CHKERRQ(ierr);
> ierr=VecAssemblyEnd(b); CHKERRQ(ierr);
> PetscViewer File;
> ierr=PetscViewerASCIIOpen(PETSC_COMM_WORLD,"Test.m",&File); CHKERRQ(ierr);
> ierr=PetscViewerSetFormat(File,PETSC_VIEWER_ASCII_MATLAB); CHKERRQ(ierr); // crash
> //ierr=PetscViewerSetFormat(File,PETSC_VIEWER_ASCII_INDEX); CHKERRQ(ierr); //works
> //ierr=PetscViewerSetFormat(File,PETSC_VIEWER_ASCII_DENSE); CHKERRQ(ierr); //works
> ierr=VecView(b,File); CHKERRQ(ierr);
> ierr=PetscViewerDestroy(&File); CHKERRQ(ierr);
> printf("[%d]: %d\n",r,__LINE__);
> VecAssemblyEnd(b);
> ierr=VecDestroy(&b); CHKERRQ(ierr);
> MPI_Barrier(PETSC_COMM_WORLD);
> PetscFinalize();
> return 0;
> Does anybody know, what's wrong with this?
> Thanks a lot,
> Hannes
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> On Jan 3, 2012, at 6:59 AM, Jed Brown wrote:
>>> On Tue, Jan 3, 2012 at 06:41, <Johannes.Huber at unibas.ch> wrote:
>>> The first assembly works well, and I would agree, if the first assmebly crashed. However, it's the second assembly call and in between those two calls, all I'm doing is viewing the vector.
>>> Use a debugger to set a breakpoint in VecSetValues(); maybe starting after your first assemble. Also try Valgrind, it could be memory corruption.
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> You can also break in the first VecAssemblyBegin and do
>>> (gdb) p &vec->stash.insertmode
>>> $1 = (InsertMode *) 0xADDRESS
>>> (gdb) wat *$1
>>> Hardware watchpoint 3: *$1
>>> (gdb) c
>>> ... breaks when insertmode is modified for any reason.
> This message was sent using IMP, the Internet Messaging Program.
